Old 9th October 2007, 11:03 AM   (permalink)
Question Using igbt in boost converter
I am currently designing a dc/dc boost converter to get the output of a solar panel (output is 17.7V) up to 100V.
to get the duty ratio i have done the calculation:
k= 1 - Vs/Vo = 1 - (17.7/100) = 0.823
I want to use an igbt for the switch, and i am getting confused about the timing calculations....
I want the igbt to switch at 20kHz so i have done the calculation:
Tp = 1/f = 50us
On the datasheet of the igbt it states the following typical values:
turn on delay time - 25ns
rise time - 17ns
turn off delay time - 215ns
fall time - 13.2ns
This totals 270.2ns which i will need to add to the Ton time to work out the total time it takes to completely turn on and off the switch.
This is the part where i am getting confused....what sets how long the switch is on for? i.e. Ton
Is the calculation below correct?
using Ton = K.Tp
Ton + 270.2ns = 0.823 x 50us
Ton = 40.88us
Basically i need to know if this is correct as these values are used to calculate the L and C values in the converter.
Any help on this would be greatly appreciated.
Thanks in advance.
elec123 is offline
Old 10th October 2007, 12:46 AM   (permalink)
20Khz? Thats a pretty Low Value For a SMPS. Most run at 100 Khz to 1Mhz to make parts small and efficient.
There are other formulas to figure out C out and L based on Freq.
http://www.daycounter.com/LabBook/Bo...quations.phtml
if your thinking about trying to get to AC voltages, forget about it. Your better off charging a battery and using an inverter.
Overclocked is offline
Boost converter help. yngndrw Electronic Projects Design/Ideas/Reviews 12 11th September 2007 06:38 PM
Pic 877A and boost converter williB Micro Controllers 15 4th May 2007 03:14 AM
Boost Converter Schematic Comments? William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 6 18th May 2006 07:38 PM
boost converter geronimo Datasheet/Parts Requests 2 17th May 2005 10:56 AM
boost converter ee01akk General Electronics Chat 1 13th April 2004 07:52 PM
