Old 5th October 2007, 07:06 PM   (permalink)
Arrow Problem with demux 74ls138
Hello,
I'm using demux 74ls138, and I'm having big problems with it.
For settings:
ENABLE = 1..................|=>now 74ls138 is working in decoder mode
Both inverted ENABLE=0 |
for any adress exepct A2=0, A1=0, A0=0 I have correct values.
When I have logical 1 on expected output I see 4.10V which is good.
When I have logical 0 on expected output I see 1.41V which is also good.
But, when I set adress A2=0, A1=0, A0=0 on output Y0 I see this:
When I have logical 1 on Y0 I see 2.84V which is not good.
When I have logical 0 on Y0 I see 0.15V which is good, but diffrent from other output values.
First I thought that I burned the first one, so I bought another one, but this 74ls138 shows same behavior.
I tried first with no load, then with load(I=~14mA), same results.
So I'm doing something wrong, but what?!
Please help it's somehow urgent, thanks.
jhanus is offline   Reply With Quote
Old 6th October 2007, 06:46 AM   (permalink)
First you have to keep
E1 & E2 LOW
and E3 HIGH
then as you change the data on A0, A1 &A2, the corresponding pin will become low while other pins remain high.
thhis is as per truth table.
How do you see logic 1? don't load the pin and have a buffer transistor to drive an LED if needed for testing
and with a diode in seires to base and a termination of sat 10K from bas to ground.
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Old 6th October 2007, 08:02 AM   (permalink)
Originally Posted by jhanus
Hello,
The output of LS138 are active LOW, that is when E1 and E2 are low and E3 is high AND 'A,B,C' are all LOW,,,
Y0 should be LOW and Y1 thru Y7 HIGH.
If 'A' is HIGH and 'B and C' are LOW , then Y1 will be LOW and the rest of the Y's will be HIGH. Look at the Table on the datasheet
Dont expect the HIGH and LOW output voltage to be +5V and 0V, most likely they will about 0.2V and +3V to +4V.
Do you have anything connected on the 'Y' outputs???
Is the Vsupply +5V?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 6th October 2007, 11:02 AM   (permalink)
I checked only demux(decoder) and manualy changed all states.
I got this:
Vcc = 5.05V
I (all) = 17mA (7segment LED + 74ls138)
I (Yo) = 11.5mA same for other ports
Y0 0.15V(0.42V) - 3.99V(3.99V)
Y1 0.15V(0.42V) - 3.99V(3.99V)
Y2 0.15V(0.42V) - 3.99V(3.98V)
Y3 0.15V(0.41V) - 4.00V(3.99V)
Y4 0.15V(0.41V) - 4.00V(4.00V)
Y5 0.15V(0.40V) - 4.00V(4.00V)
Y6 0.15V(0.39V) - 3.99V(3.99V)
Y7 0.15V(0.42V) - 3.99V(3.99V)
Y0-Y7 are outputs, in brackets is voltage under load. Every output is connected to one cathode of LED display.
Here is how I connected it:
Click
Voltages on PIC are:
If I have logical 1, on output I see 3.49V( it stays same with and without 74ls138)
If I have logical 0, on output I see 0.00V( it stays same with and without 74ls138)
Now I know why I have 3.49V on output of PIC, I'm constantly , every 10us changing value of the port to 0V. Because I don't have oscilloscope I measure it with voltmeter, so my measured voltage is not accurate and I forgot that.
I will try to eliminate switching and post again.
Old 6th October 2007, 12:22 PM   (permalink)
The output of an HCT device is not strong enough to pull to ground through a LED and a resistor. In your original post you said you had an LS part. So which is it? Also, a CMOS output stage is a very different animal than a TTL totem pole output.
Papabravo is offline   Reply With Quote
Old 6th October 2007, 01:15 PM   (permalink)
I have SN74LS138N, in hurry I set the wrong demux in picture.
Old 6th October 2007, 02:18 PM   (permalink)
Well now it's working fine, that is when I disable port switching, but my initial idea was to fast switch demux so that human eye can't see the switching of 7seg diodes.
What now? If I fast switch then I get again those side effects, is this normal?
Old 6th October 2007, 02:21 PM   (permalink)
How fast are you switching, can you post your program??
Eric
PIC tutorials:
Old 6th October 2007, 04:03 PM   (permalink)
I'm switching every 10us (4MHz crystal).
BUT
It is alive, it's working, I don't know what I done diffrent, but I reconnected everything and in steps bit for bit tested, in the end I fast switched.
So thank you all for helping me!
Expect more(problems) from me!
JDM programmer problem krvavizmaj Micro Controllers 3 2nd October 2007 08:35 AM
Strange problem tkvenki Micro Controllers 1 3rd May 2007 11:39 AM
RF tranceiver problem darvaish General Electronics Chat 2 3rd April 2005 07:44 AM
Big thermocouple ADC problem Oznog General Electronics Chat 9 4th May 2004 08:42 PM
strange color camera problem schrodingerscat Electronic Projects Design/Ideas/Reviews 5 4th October 2003 07:25 PM
