Old 5th October 2007, 01:30 PM   (permalink)
Default need help with 0-99 counter
can you give me an ideal in how to make a 0-99 counter. I hope you can help me in this matter.
thank you.
AND
AND_ECE is offline
Old 5th October 2007, 01:45 PM   (permalink)
Probably the easiest way is to use a micro-controller, there's a PIC example in my tutorials, using two seven segment displays.
Old 5th October 2007, 01:56 PM   (permalink)
thank you.
Can you write a PIC program?, or must you use logic ic's?
Where are you posting from?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 5th October 2007, 03:22 PM   (permalink)
Here's a three digit counter in a thread elsewhere on this site. Just don't build the third digit.
http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/22569-help-down-counter.html
Bill
Smart Kits build Smart People
Old 5th October 2007, 10:05 PM   (permalink)
Note that Bill's circuit is incomplete.
It needs 100 nF capacitors across the counter IC supply line (one for each 4510), the Load, A, B, C & D inputs should be connected to gnd. And, if you want it to count up, connect the UP/DN inputs to +9 Volt.
The 4511 requires a Common Cathode 7 seg. LED display.
The Enable input of the 4511 should be connected to gnd.
CMOS inputs should not be left open.
Len
ljcox is offline
Old 6th October 2007, 02:06 AM   (permalink)
Not my circuit just found it by searching these forums.
Bill
Old 12th October 2007, 07:53 AM   (permalink)
thanks a lot
AND
AND_ECE is offline
Old 13th October 2007, 12:53 PM   (permalink)
Wink Easy for counter
thank you.
Are yaar just go to maxim site search counters
www.maxim-ic.com
U will get atleast 3 free samples from them
So do the project free of
gbmewada is offline
Dual counter bananasiong Micro Controllers 45 24th March 2007 03:49 AM
How we can do it in Assembly..Help Needed Ayne Micro Controllers 37 29th December 2006 06:49 PM
Input Counter Pic16F84A (Code problems) loco Micro Controllers 4 26th September 2006 02:19 PM
[help] Power consumption issue on bullet counter project * Lanzer Electronic Projects Design/Ideas/Reviews 13 26th August 2005 07:06 AM
Crude assembly counter Mark Lazarides Micro Controllers 5 28th February 2004 08:22 PM
