I plan to build a small battery-powered (2x9V) tester to test the operation/alignment of 24vdc industrial sensors while showing whether the output is pnp or npn, using the 18v supply to power the sensor. I'd like to add an LED to prove that the sensor's supply is hooked up while in its unswitched and output-unconnected state. Is there a simple method to light an LED when a current draw is sensed? (most of the sensors probably draw a few mA in their unswitched state). As I don't plan to have an on/off switch it would also be spiffy if the current draw, with sensor unconnected, is teensy. BTW, RS Components sells this gadget for around US$100! | |
| | #2 | |
Can you explain what you mean by output is pnp or npn. Do you mean a negative voltage or positive voltage swing?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #3 | |
Here is something similar to what RS offers for extortinate prices: http://www.alliedelec.com/Search/Pro...0&R=538%2D0002 | ||
And from that link: "If the tester is improperly connected to a sensor, a safety feature prevents damage to either to tester or the sensor. " I wonder if that's simply a 5c diode | |
| | #5 | |
Are located in UK?
| | #6 | |
| detected, led, light, load |
| solar blinking LED HELP | team_nightstalker | Electronic Projects Design/Ideas/Reviews | 33 | 26th October 2007 06:05 PM |
| Inchworm adapter bd | lemonyx | Micro Controllers | 9 | 9th May 2007 08:01 AM |
| Validating Code Without PIC | burg | Micro Controllers | 4 | 22nd April 2007 05:14 PM |
| Light sensor with LED's | mcs51mc | Electronic Projects Design/Ideas/Reviews | 13 | 7th July 2006 06:34 AM |
| Motor Torque | watzmann | General Electronics Chat | 5 | 8th September 2005 02:26 AM |
