Old 3rd October 2007, 01:02 AM   (permalink)
The BD139/BD140 little power transistors have a max allowed current of 1.5A. That is the peak current of a sinewave with a power of 9W into 8 ohms.
An amplifier has a voltage loss at its output of about 2.5V. Then the peak-to-peak voltage swing with a 12V supply is 9.5V. Then an amplifier can make 3.5V RMS into 8 ohms which is a power of only 1.5W. The average power supply current is about 250mA.
The little power transistors have a low current gain like all power transistors. Then the transistor feeding them has a high output current which reduces its voltage gain and reduces the amplifier's negative feedback. Then the distortion is high.
Amplifiers usually use driver transistors to drive the power transistors so that the voltage amplifier transistor can have a high voltage gain, and a high amount of negative feedback can be used in the amplifier resulting in low distortion.
audioguru is offline
Old 3rd October 2007, 01:16 AM   (permalink)
hmmm does it matter? i don't want it to hear music!
i have made many builds to enjoy myself.... DACs, LM3875 Gainclone amp, TDA1553Q amp etc... but this is the first time i'll make an amplifier which is not Chipamp... so it it wrong to start with something small that i can understand?
whiz115 is offline
Old 3rd October 2007, 04:33 AM   (permalink)
There are many simple good circuits. Make one that works well.
Old 3rd October 2007, 04:56 AM   (permalink)
I think a great learning amp that works as a headphone amp is here:
http://sound.westhost.com/project113.htm
Real common way of doing things from what I understand. Should drive any headphone on the planet. I've got parts for a (modified) version I am working on now.
speakerguy79 is offline
Old 3rd October 2007, 04:27 PM   (permalink)
looks easy and very simular to what i'm studing here!!! but it uses
IC it's not totaly from discrete components and also i think it needs a PCB..
i don't think i can make it on a breadboard probably it will behave far
worst even than the amp that Audioguru advices me not to build.
whiz115 is offline
Old 3rd October 2007, 05:46 PM   (permalink)
You will very likely have oscillation problems on the breadboard from reading the article. You will have large capacitive coupling between the + and - inputs due to the structure of the breadboard. I did not know you couldn't use an op amp, sorry.
Old 8th November 2007, 12:38 AM   (permalink)
Heres the simplest amp i could find.
http://scitoys.com/scitoys/scitoys/c...amplifier.html
wmmullaney is offline
Old 8th November 2007, 01:07 AM   (permalink)
So did you read the web page before or after starting the other thread?
mneary is offline
Old 8th November 2007, 04:09 AM   (permalink)
It is a very lousy amplifier. Read what I said about it in the other thread.
Old 10th November 2007, 06:20 PM   (permalink)
audioguru,
You little amplifier needs emitter resistors to prevent the transistors from going in to thermal runaway.
Screen name: Aloone_Jonez
Hero999 is offline
Old 10th November 2007, 06:35 PM   (permalink)
Originally Posted by Hero999
audioguru,
Probably not?, as it's under-biased - particularly if the bias diodes are thermally coupled to the output transistors. But really it's a just a piddling little amp, based on the minimum component count.
« Schematics | Op-amp »
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 31 13th October 2008 05:35 PM
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 2 25th November 2006 09:17 AM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 06:34 AM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 11:46 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
