Old 1st October 2007, 02:34 AM   (permalink)
Default Circuit to soft-start 300 watts of lighting?
Something to bring them from off to full brightness in around a second would be spiffy.
I already have a 500 watt dimmer - is there such a beast as an automatic and time-adjustable "electronic pot" that I could build and just substitute for this dimmer's pot?
NewUser is offline
Old 1st October 2007, 06:01 AM   (permalink)
How does the 500 watt dimmer work? If it runs off of a signal from a POT then you could replace the POT with a large capacitor and a resistor tuned to go from 0 volts to full voltage over a short period of time.
straight answer, har har."
Sceadwian is offline
Old 1st October 2007, 09:19 AM   (permalink)
http://www.geocities.com/tomzi.geo/dimmer/dimmer.gif
Assuming this circuit is similar to what I have, would it be as simple as
replacing the 470k pot with a series-connected capacitor and resistor?
NewUser is offline
Old 1st October 2007, 09:28 AM   (permalink)
The dimmer posted works by the pot/cap changing the firing angle of the triac.
Changing as you stated wouldnt help.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 4th October 2007, 10:54 AM   (permalink)
Would a FET work in the above 230V circuit as a substitute for the pot?
NewUser is offline
Old 4th October 2007, 12:20 PM   (permalink)
You still have to control the FET even if you can find one that works high voltage.
I would suggest a simple and effective solution using optical feedback. It involves using an additional small wattage(1~3W) 230V filament lamp and a LDR(light dependent resistor). Mount the LDR close to the lamp so that the lamp shines onto the LDR, but the setup should be light tight.
Set your dimmer POT so that the small filament lamp just start emitting light. Due to feedback action, the lamp(and the 300W external lights) will eventually goes full brightness.
L.Chung
eblc1388 is offline
Old 4th October 2007, 01:22 PM   (permalink)
No.
Have a look at this circuit I have added a NTC thermistor and a 'heating' resistor, this would give an initial slow start.
Eric
PIC tutorials:
Old 5th October 2007, 08:18 AM   (permalink)
OK thanks guys, will give those ideas a shot.
NewUser is offline
Old 5th October 2007, 06:35 PM   (permalink)
Digikey sells "inrush current limiters", basically very low resistance NTC thermistors. For 300W 230V you might get KC013L-ND which starts out cold at 50 ohms and then heats up to about 0.75 ohms. $2 or less.
There's a similar device in most PC SMPSes that I've taken apart.
mneary is offline
Led cyclic dimmer/controller circuit? yel-low Electronic Projects Design/Ideas/Reviews 13 9th August 2004 05:00 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 04:07 AM
Timed fades circuit for stage lighting desk cpnick Electronic Projects Design/Ideas/Reviews 2 18th February 2004 10:46 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
Random timer circuit required Tako Kichi Electronic Projects Design/Ideas/Reviews 0 11th October 2003 04:07 AM
