Old 28th September 2007, 11:14 AM   (permalink)
i see. yeah i connected to resistor and cap already. when i switch it do i on and off? or just turn it on?
konzen is offline
Old 28th September 2007, 11:18 AM   (permalink)
The START switch is closed just 'one time' after you have got the power switched on to the ADC, then switch it OFF. [open]
Dont leave the START switch ON, its just needed to start the ADC ic running.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 28th September 2007, 12:40 PM   (permalink)
do i have to pulse the start switch? or simply turn it on? i have a vref and the analog input voltage is provided by a voltage divider made up of a potentiometer and a fixed biasing resistor
konzen is offline
Old 28th September 2007, 12:43 PM   (permalink)
okay ill try
konzen is offline
Old 28th September 2007, 01:04 PM   (permalink)
Just pulse it once, after you have connected power to the ADC.
That will start it going.
Eric
PIC tutorials:
Old 28th September 2007, 01:07 PM   (permalink)
i solved the problem. the problem was caused by a wrongly connected pin. the circuit works fine now. however, it seems to work even without pulsing the switch. this seems weird. by the way i'm running the whole thing on a 6 V dc power supply. any simple ideas on how i can reduce it to 5? i tried biasing with a 2k and a 10k resistor but it doesn't work
konzen is offline
Old 28th September 2007, 01:14 PM   (permalink)
Try this, it should be OK.
Eric
PIC tutorials:
Old 28th September 2007, 01:17 PM   (permalink)
how does that work?
btw should i just leave the switch as it is? it seems to not be contributing to the circuit
konzen is offline
Old 28th September 2007, 01:21 PM   (permalink)
how does that work?
Sometimes the ADC will work without the Start switch, but sometimes it won't, so leave the switch in as the datasheet says. Use it when it dosn't start itself, OK
The diode 1N4001 drops about 0.7Volts.
Eric
PIC tutorials:
Old 28th September 2007, 03:13 PM   (permalink)
okay.
oh yeah! how did i not think of that. diodes have constant voltage drops cool.
thanks.
konzen is offline
Old 9th October 2007, 03:55 PM   (permalink)
im done with my project. demoed it yesterday. thanks alot for helping me with the ADC. here's a pic. cheers
konzen is offline
LM3914 Help - Battery Monitor Circuit Needed! Skyone Electronic Projects Design/Ideas/Reviews 19 15th August 2006 11:32 PM
Newbee help needed on a 12v circuit. (Swithced resistor) stubs Electronic Projects Design/Ideas/Reviews 13 10th January 2006 07:20 PM
Circuit Needed Please jkon General Electronics Chat 2 19th December 2003 02:39 AM
Voltage Comparsion Circuit needed waqar Electronic Projects Design/Ideas/Reviews 1 16th May 2003 01:10 PM
info on how to make your own circuit boards needed Richie086 General Electronics Chat 2 2nd May 2003 02:10 PM
