| Although there exist very high bandwidth optocouplers, I’ve found many IGBT/MOSFET drivers still use pulse transformers for isolation. Why is it the case, when we know that optocoupler has no need for number of turns calculation, winding, etc. and is easier to assemble and does not require extra latch/Schmidt trigger circuits. Someone told me pulse transformer gives better and more reliable Isolation, is it the case? Thanks for replies in advance | |
| It is an interesting question. What is your experience with either method? | |
| I would suggest three reasons: 1) Pulse transformers were about LONG before opto-couplers. 2) Pulse transformers are much more reliable. 3) A pulse transformer can actually transfer power, simplifying the secondary circuit. | |
| 4) you need alot higher isolation then commercial opto's provide thus winding yr own can provide this 5) you have silly design rules that say "tho shall not use opto-electronics" | |
__________________ E Cerfoglio Buenos Aires Argentina | ||
| The LED in opto-couplers fades with time so the output becomes less and less. A transformer doesn't.
| I suspect that opto-isolators have replaced pulse transformer in many applications, but there may always be cases where the transformer may have advantages as already stated and say where you require a center tapped secondary so that two 180 degree out of phase signals are available. Lefty
__________________ Measurement changes behavior | |
| Thank you all. Besides, pulse transformers are bidirectional, you can send PWM and receive fault signals via the same transformer (in the form of very short duration impulses). | |
| Why hasnt anyone stated the most obvious reason. Opto-couplers cannot provide AMPS of gate current to switch a power device fast. A pulse transformer CAN. | |
| Can they be use for communication say RS 232 ?? | |
| Problem measuring pulse width - 12F683 TMR1, 8MHz | jess | Micro Controllers | 18 | 5th February 2007 11:00 AM |
| Problems selecting a PCB Transformer | NewcastleSAR | Datasheet/Parts Requests | 31 | 4th January 2007 08:16 PM |
| pulse on, pulse off latching switch | b1mmuo27 | Electronic Projects Design/Ideas/Reviews | 15 | 23rd November 2005 02:18 AM |
| Fuel injector pulse detector | brjones | Electronic Projects Design/Ideas/Reviews | 3 | 31st August 2004 09:07 PM |
| Pulse Width Calculation | waqar | Micro Controllers | 1 | 25th June 2003 12:54 PM |
