With that voltage R4 dissipates 1W and the other 3 resistors less than that, so it is the limit of the circuit. Of course, with more than 7.07V R4 would overheat, smoke and burn.
__________________ E Cerfoglio Buenos Aires Argentina | ||
| Yes you are correct. Using 1W resistors, the voltage must be limited to 7.07V then R4 dissipates its max of 1W and the remaining resistors dissipate 1.666W. Then the total dissipation is 1.666W which certainly is less than 2W.
| Hi Sorry because of my late reply Thank you all guys for your response I did some calculations and now I understand what I need Once the tow branches have different values 50 Ohm & 75 Ohm So there must be a difference in the watt capacity in order to have 4W 30 Ohm resisor I did the calculations in order to have the new wattage for each resistor So I found that Pr4=2.4 Watt Pr2=1 Watt Pr1=Pr3= 0.26 Watt Thanks again
__________________ I’m from Syrian Arab Republic where lots of guys are trying to do better in electronics. | |
(Bothered by such a simple task)
__________________ Luis German | ||
I also suggest you don't be rude to moderators!. | ||
| WTFingF is with some people?! Re the question and the matter of answering it, I'd agree with HiTech here: it's not just doing the maths but having a decent sense of how to apply it. I think that sort of thing comes with practice, and when you're new it's easy to slip up. Tronicbrain: You saw that the actual resistance value was correct at least, the problem was just that R4 will dissipate more power than it is rated for. HOWEVER, you could replace R4 with 4 resistors of the same type: 2 in series, in parallel with another 2 in series. That set of resistors would have the same total resistance (50 So anyway, you could make this whole 30 | |
Go cry to someone else. | ||
| About feedback and comments | pwotoole | Feedback/Comments | 10 | 14th May 2007 11:04 PM |
| Small display | rik | Datasheet/Parts Requests | 3 | 23rd September 2003 10:56 PM |
| 12v mobile small power source | lazynok | Electronic Projects Design/Ideas/Reviews | 1 | 9th June 2003 09:05 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 07:21 PM |
| Current Question | johnsz | Electronic Projects Design/Ideas/Reviews | 3 | 22nd February 2003 09:56 PM |
