+ Reply to Thread
Results 1 to 13 of 13
Thread: Restart cell phone circuit
  1. #1
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    Default Restart cell phone circuit
    Hi everyone, I have a cell phone that locks up every few days. It requires a restart by holding the power button down for about 2 seconds. Then once it is off, you have to hold the power button down again for 2 sec. I wanted to automate this process. Im thinking about using a PIC to control a transistor to short the power button out every 48hrs. Is this possible? Im a beginner, but have a little experience with electronic circuits...
    Thanks,
    Tommy
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,705
    Blog Entries
    5
    Just exchange the phone, if you hack it you'll void any warranty.
    Bill
    Smart Kits build Smart People
  3. #3
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    Well, I need to do it this way. I have several of the same model so if I break some of them, thats ok. The software that is running on the phone is all custom, and has many flaws. This is why I need to power cycle the phone every now and then. So Im basically looking for a circuit that will complete a second low current (I would assume) circuit. I just need the circuit to be closed for about 2 seconds, then open. Every day or so, complete the circuit and repeat.
  4. #4
    MalcolmV8 Newbie
    Join Date
    Sep 2007
    Posts
    27
    Where are you going to put this circuit? attached to the back of the phone? Or on a base that the phone docks to at night or something?
  5. #5
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    Back of the phone. Im not really to worried about how it looks. The entire device will be in a box of its own. The cell phone case is not even attached.
  6. #6
    MalcolmV8 Newbie
    Join Date
    Sep 2007
    Posts
    27
    And this is your daily use cell phone? or just an extra phone for a project?
  7. #7
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    Extra phone.
  8. #8
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    So does anyone have an idea if a transistor will work or should I use a relay? The circuit that runs the timer will be drawing current from the phones battery.
  9. #9
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    It depends entirely on the circuitry of the phone, a relay will always be OK, a transistor 'may be', depending on the design.
  10. #10
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Quote Originally Posted by tremmert
    A small reed relay would mean you would not have to analyze the phone's circuity, just parallel the existing switch. There are some pretty small 5vdc coil low current reed relay packages so size shouldn't be a problem. A small 8 pin pic could be programmed to trigger the relay but a couple of 555 timers might be made to work.
    Good luck.
    Measurement changes behavior
  11. #11
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    Awesome, I will do some research on the reed relay, and use a pic to control the timing. Thank you all for your help!
  12. #12
    pixnum Bad
    Join Date
    Jul 2006
    Location
    Kolkata,India
    Posts
    59
    Thanks,
    Tommy
    Dear Tremmert,
    Before going to use your electronics skill to solve your problem, you can use secret codes methods of your mobile phone by using
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    N.B. These codes are for Samsung mobile phones(USE IT AT YOUR OWN RISK)
    Thank you,
  13. #13
    tremmert Newbie
    Join Date
    Sep 2007
    Posts
    9
    Thanks for the post, but this is a Motorola phone that Im trying to reset... Thanks again
+ Reply to Thread
  1. major breakthrough in cell phone
    By johnson_dsouza23 in forum Micro Controllers
    Latest: 8th February 2006, 06:43 PM
  2. Charge Management System for Cell Phone Batteries
    By sandeep_patalay in forum General Electronics Chat
    Latest: 7th July 2004, 04:50 PM
  3. Cell phone interfacing...
    By karim abdel HAMID in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th March 2004, 12:14 PM
  4. Cell Phone Jammer Plans
    By jelly in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th November 2003, 03:09 AM
  5. Mobile Phone led detector circuit wanted please
    By kevinv in forum General Electronics Chat
    Latest: 28th September 2003, 10:18 AM
Tags for this Thread
