Friends:
After you solder a circuit board, what do you wash the flux residue off with? I am hesitant to use water for fear of subsequent corrosion, and have no clue as to what kind of flux is in my solder wire. Thanks for your advice! -Migs
"Sometimes we forget that the world itself is paradise." Douglas Coupland, 'Microserfs' "We either make ourselves miserable, or we make ourselves strong. The amount of work is the same." – Carlos Castaneda "One single grateful thought raised to heaven is the most perfect prayer."- G. E. Lessing |
Hi migs, i use a flux removing spray, you should get that from most electronic suppliers, i use maplin or rapid electronics here in the UK. I spray it on, leave for a few seconds and work it with an old toothbrush then spray it again to clean off any remaining residue. works every time.
billboard. |
Thanks billboard, I will search for some. If I cant find some, do you think medicinal alcohol will work?
Migs
Experienced Member
But be careful, Acetone is Flammable and is definately also not good to Breathe. This Rosin flux will NOT be removed with water. I use a "Kester 331" Solder. It has a Water based flux built into it and just rincing the board Under Warm tap water Removes all the flux. "Almost All electronic parts are quite Water Safe". Just remember to dry the board completely before connecting to any power source.
I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec |
Thanks chemelec!
I will try the water test at lunch to see if my solder flux clears off. Migs
Experienced Member
I rub it on with an acid brush that has its bristles cut short to give it a better scrubbing action. Then just dry with a paper towel. It is probably the safest of the usable solvents. |
Good to know Rolf! I'll try that too. -Migs
Experienced Member
Better yet, use the IPA found in home improvement, paint or hardware stores sold as "alcohol", designed for use as shellac thinner. It's 100% isopropyl alcohol and available in pint or gallon cans. Old toothbrushes work well for scrubbing and you can use floss to get underneath components on the other side (just kidding, just kidding!). For larger boards, fingernail brushes work well. Just remember that the brushes will cause splatter, so wear eye protection and keep your bench clear of things that you don't want splattered.
More dangerous because of explosion/fire and inhalation hazards, either lacquer thinner or acetone work much faster for non-water soluable fluxes. Two runs with the stronger solvents and a final rinse with IPA will leave your board clean as a whistle. Overall, I'd suggest doing it outside on the driveway just to be safer all around. However, remember that flux removal, for the most part, is a cosmetic thing. Flux at room temperature is inactive and non-conductive, and as long as your circuit board is installed where you can't see the solder side, I wouldn't mess with it. Dean
Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. |
Experienced Member
A can of FluX-Off will work.
(permalink) | ||
Moderator
A liquid flux pen can be a great aid when soldering, esp bare copper. Flux pens come with several different types of flux. Some pens like the Kester #2332-ZX are excellent at getting the solder to flow and make very nice joints. But it must be removed. What it leaves behind can keep you circuit from working. The residue from other flux pens can be left on the board with no ill effect. Check the datasheet on the pen you buy. Often times when a "new and improved" way or product is mentioned, another person will post about how they do without. In this case look for a post like: Quote:
Hi 3vO
The reason I ask is because I was building a Sumovore Sumo Robot kit with my son, and the instructions mentioned cleaning it off for better results. I do appreciate all of you all's comments. As life goes on I have learned the great power of forums for enlightenment. You guys are all great! -Migs
Super Moderator
Experienced Member
Corrosive fluxes are normally removed with water or IPA. It doesn't usually matter with the rest of them.
Experienced Member
Secondly, Contrary to Manufacturers Claims, Most Rosin Fluxes are Somewhat Conductive. ** Especially in Sensitive Circuits and more so in a high humidity enviroment. I Always Recommend Removing the flux on all Boards.
| Flux? (Leds) | Andy1845c | General Electronics Chat | 17 | 10th December 2006 11:25 AM |
| Flux vs Solid Core Solder Wire | dknguyen | Chit-Chat | 6 | 10th September 2006 04:50 PM |
| Flux cleaner | pittuck | General Electronics Chat | 16 | 14th October 2005 01:32 PM |
| excess flux | RonDumas | General Electronics Chat | 6 | 14th August 2004 12:29 AM |
| Flux! - It's not a dirty word. | Squintz | General Electronics Chat | 13 | 10th November 2003 08:58 AM |
