| Notices |
| | (permalink (permalink)) |
| Hello friends, I built the circuit on the main page here: http://www.serasidis.gr/circuits/RF_...te_control.htm I did the same thing only I used an avr 90S2313, and a 9 Volt battery with a 5 volt regulator. The transmitter module and the avr are working from 5 volts. Everything works perfectly except In the transmitter, the battery goes dead within one day. Anyone have experience with this circuit? Could the regulator be draining the battery somehow? The software puts the microcontroller to sleep so that it does not use much power. I am sure that it is not a software problem. Anyone with any experience with these modules? | |
| Hi John, Why use the regulator with the transmitter? It's not on the schematic, and with the voltage input range those chips accept, I wouldn't think it's needed when running from a battery anyway. Why run the circuit on 5V when 3V will do the job? Or 4.5V, which you could get from 3 AA cells with probably better capacity than the 9V. http://en.wikipedia.org/wiki/Battery...nd_discharging The regulator itself takes power to do its job, and unless it's a low-dropout regulator you probably don't want to use it. Try removing the regulator and running the thing off of 3 AA cells. Torben | |
| hello guys, thanks for the input. Firstly I am using the parts I have here without having to order anything. I am trying to make due with what I have. I was using the regulator because I am running a 90S2313-10 micro with the RF module. The 90S2313 requires a minimum of 4 Volts. So I thought I would run a 9V battery, but in less than 24 hrs, it went dead! I didn't have a battery holder for 3 AA batteries. I have since re-worked the remote so that it does disconnect the battery when not in use. When the button is pushed, the power is connected briefly in order to send the data packet, then it disconnects the battery and waits for the button to be pushed again. I think this will do the trick. Thanks again for the input! | |
| There ya go. Also, if you happen to wander through a Radio Shack or whatever and get a chance to pick up a holder for the AAs (you could probably get away with 4 AAs too, as long as fresh ones don't exceed 6.6V IIRC--the holder might be more common), you can always pull out the regulator and use those instead of the 9V. Together with your power-on-demand switch setup, that should give you capacity for ages. At any rate, good going and good luck! Torben | |
| I'd like to try 3 AA batteries without modifying the code.(4.5V NO regulator.) That is, keep the micro running in sleep mode, and wake it with a keypress on low level interrupt. Just curious on how long the battery will last. I installed the transmitter approx 170' away from the receiver, and it works like a charm. I am using a 3" copper wire for an antenna for both RX and TX (the center conductor from an RG6 cable) The transmitter is outside, in my mailbox. When the mailbox is opened, it signals the receiver to turn on an led and beep a buzzer. The led stays lit until reset. We can't see the mailbox from the house, so it's nice to know whether we have mail or not. I am also curious to know how the circuit will perform in the freezing cold winter. Last edited by johnsmith123; 22nd September 2007 at 11:31 AM. | |
| | (permalink (permalink)) | ||
| | (permalink (permalink)) | ||||
n.b. Somebody who sees problems with my math/assumptions please beat me (gently) with a clue stick if I really screwed that up. Quote:
It also depends on the batteries; chemical reactions slow down in cold temperatures. I am not too sure what the best cells for your temp. range would be. I also can't tell you about how the crystal will respond, although I'd guess it will slow a bit. Enough to affect the circuit? I don't know. Torben Last edited by Torben; 22nd September 2007 at 09:08 PM. | |||||
| IR remote control | flavius | Electronic Projects Design/Ideas/Reviews | 5 | 12th September 2005 04:06 PM |
| Remote Control | Clyd3 | Electronic Projects Design/Ideas/Reviews | 18 | 14th August 2005 03:29 PM |
| Building a Very Simple Remote Control.. | chui | General Electronics Chat | 1 | 19th December 2004 10:29 PM |
| Connecting a microcontroller to an RF Remote control. | DaMoN | Electronic Projects Design/Ideas/Reviews | 2 | 12th September 2003 08:45 PM |
| 4 channel IR remote control | mengchan | Electronic Projects Design/Ideas/Reviews | 3 | 6th July 2003 09:21 AM |
