Old 19th September 2007, 05:44 AM   (permalink)
Default leds
how to determine the forward bias voltage for red, green, blue led?
shermaine is offline
Old 19th September 2007, 06:15 AM   (permalink)
A resistor, an ammeter, a power supply and a voltmeter.
Papabravo is offline
Old 19th September 2007, 06:23 AM   (permalink)
Take a variable DC supply that starts from about 1.5V & give to the LED. You won’t see it lights up. Now slowly increment the voltage & see what voltage the LED starts to lights up. That’s the voltage you looking for.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 19th September 2007, 02:11 PM   (permalink)
LEDs operate with current, not voltage.
You must use a current-limiting resistor in series with the LED so you don't use too much current.
Then simply measure the voltage across the LED.
audioguru is offline
Old 19th September 2007, 10:38 PM   (permalink)
Simply connect the LED in series with a resistor and connect it to a power supply and measure the voltage across the LED.
Screen name: Aloone_Jonez
Hero999 is offline
Old 20th September 2007, 05:26 AM   (permalink)
The easiest way is to read the data sheet.
kchriste is offline
Old 20th September 2007, 02:18 PM   (permalink)
It will say the range of forward voltage. If it is a red LED it will say "minimum= 1.5v and maximum= 2.4V at only 20mA".
You must measure it to know what is the actual forward voltage.
Old 20th September 2007, 04:13 PM   (permalink)
Default Some typical forward voltages for various LEDS
All data @ ~ 10mA forward current
I.R. = 1.40V
Red = 1.65V
High-Efficiency RED = 2.20V
Pink = 2.00V
Orange / Amber = 2.10V
Yellow = 2.20V
Green = 2.20V
High-Efficiency Green = 2.30V
Blue = 3.10V
These are *TYPICAL* values.
These values will differ from vendor to vendor.
Optikon is offline
Old 20th September 2007, 04:15 PM   (permalink)
Ive never seen a pink LED. What are the voltage ratings for Organic LEDs?
Krumlink is offline
Old 20th September 2007, 04:53 PM   (permalink)
The LED's I got from moreleds.com are:
Blue: 3.3V
White: 3.3V
Red:1.7V
Green:1.7V
all were ultrabright LED's, more than 5000mcd.
The other site to check out is: http://alan-parekh.vstore.ca/index.php/cPath/4
Ambient is offline
Old 20th September 2007, 08:05 PM   (permalink)
Blue: 3.3V
White: 3.3V
Red:1.7V
Green:1.7V
Interesting.. what current were they measured at?
Optikon is offline
Old 20th September 2007, 09:01 PM   (permalink)
Cheap LEDs are very bright when the plastic case makes a very narrow angled focussed beam from a dim old LED chip.
Good LEDs are wide angle and very bright.
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
A Basic Question of Efficiency - 4 LEDs in parallel or series!?! Agent M Electronic Projects Design/Ideas/Reviews 9 27th December 2006 04:23 PM
LEDs from the Far East. ThermalRunaway General Electronics Chat 12 15th August 2006 02:37 AM
Long-life circuit for LEDs and a clock dabuttery Electronic Projects Design/Ideas/Reviews 4 22nd February 2006 04:16 PM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 05:55 AM
