Old 16th September 2007, 01:01 PM   #1
Default Convert binary to BCD code
I'd like to know how to convert one of my 4bit codes to a BCD code.
genetica is offline
Old 16th September 2007, 01:22 PM   #2
Is that a 4 bit binary code to bcd?, or to hex?
Have a look at this thread:
Binary input Hex dispaly (7 segment LED)?
ericgibbs is offline
Old 16th September 2007, 02:16 PM   #3
4bit binary to BCD.
genetica is offline
Old 16th September 2007, 02:22 PM   #4
4bit binary to BCD.
I must be missing something.
Isnt 0 thru 9 binary, BCD anyway??
Can you post a sample bin pattern?
Old 16th September 2007, 02:49 PM   #5
Well i got a random sequence for certain numbers
0 1110
1 1101
2 1011
3 0111
4 0001
5 0010
6 0100
7 1000
9 0000
8 all the rest.
And i like to convert them to BCD 8421 code.
I made a karnaugh diagram a created a circuit for the four inputs and then fout outputs a circuit for each bit. But the circuit is like huge.
genetica is offline
Old 16th September 2007, 02:58 PM   #6
0 1110
1 1101
2 1011
3 0111
4 0001
5 0010
6 0100
7 1000
9 0000
8 all the rest.
Have you considered using an EPROM ic, load the pattern you want out as the data and the 'odd bit' pattern as the address?
EDIT:
IF this is related to the 7seg Driver thread, the EPROM output data could be the 7seg driver data!
Old 16th September 2007, 03:23 PM   #7
This drawing shows the method.
Old 16th September 2007, 03:37 PM   #8
Thanks ill do the Eprom.
genetica is offline
bcd, binary, code, convert
Convert serial LCD code into parallel LCD.. Help please.. AntRoFiZ Micro Controllers 10 22nd May 2007 02:07 PM
Trying to convert binary to ascii ChriX Micro Controllers 9 7th May 2005 01:30 PM
Tough assembly program for the PIC16F84 asmpic Micro Controllers 34 3rd December 2004 07:50 PM
converting binary number to ASCII code david_mora Micro Controllers 7 24th May 2004 10:08 PM
An error in pic16f84a, why? Zener_Diode Micro Controllers 6 11th April 2004 03:55 AM
