Old 13th September 2007, 08:52 AM   #1
Default Lead Acid Battery
there is a problem that i had buy a new lead acid battery. according to the company i should add the electrolyte of specific gravity 1.25. because it was dry
charged battery. but i do a mistake that i add the electrolyte of specific gravity 1.20. at the result the battery does not perform well because the terminal voltage of battery reaches to 14 during charging but the specific gravity of the acid does not increases more than 1.20.
NOW what should i do.
should i change the electrolyte with specific gravity 1.25?
dimper129 is offline
Old 13th September 2007, 08:38 PM   #2
1 charge he battery fully, until it bubbles for 10 minutes.
2 pour out the acid into a plastic container
3 gradually add concentrated acid, stirring all the time, until the acid is sg 1.25
4 pour the acid back into the battery.
spuffock is offline
Old 18th September 2007, 07:55 AM   #3
Thank you for the help
i am still facing a problem
i bought new acid of sg=1.25 and followed the steps
i kept the battery inverted one whole night.
next day i put the new acid into battery
the sg improved a bit but its still 1.23, i think it is because there was still some acid of low density in the FORM between the plates. how would i drain that out and dry the battery complely before pouring the new acid in?
Thanks a lot!
Old 18th September 2007, 10:23 AM   #4
Perhaps you could use acid with a slightly higher specific gravity, like 1.3, then dilute it accordingly when you've filled the battery or just pour out some of the existing 1.23 acid and add more concentrated acid until you get the mixture right.
if I know the answer.
Hero999 is offline
acid, battery, lead
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 1 4th October 2008 01:26 AM
Lead Acid battery charger manojp01 Electronic Projects Design/Ideas/Reviews 5 29th January 2008 06:17 PM
Lead Acid Battery Charger Help Request jagzviruz Electronic Projects Design/Ideas/Reviews 17 16th January 2007 11:46 AM
DS2438 with 12V lead acid battery monkeytennis General Electronics Chat 2 29th August 2006 01:45 PM
12v Sealed lead acid battery charger andi_n2004 Electronic Projects Design/Ideas/Reviews 1 27th April 2004 01:52 PM
