Old 12th September 2007, 07:10 PM   (permalink)
Default Photo Sensitive Clock Signal
Well I will try to give you as much information as possible. Am am trying to build a circuit that will produce a clock signal for a counter. However this clock signal should be triggered by a change in light for a photo transistor or photo resistor. I have VTT7122 photo transistor and VT906 photo conductive cells available.
Per say:
A cup is resting on top of the photo transistor. When I lift the cup or object it will create a clock signal that will increment a counter by one. The table will be have plenty of ambient light to ensure that the photo transistor work properly.
Sorry I did not specify earlier, but i would like to make it using only IC's if possible. IF this is not possible what micros are good to work with that you have had good experience with.
Any help is greatly appreciated.
omega3387 is offline
Old 12th September 2007, 07:44 PM   (permalink)
Your bigger problem will be to ensure that there will be only one count each time the cup is lifted.
Use a schmidt (spelling?) trigger between the phototransistor and the counter. Perhaps one gate from a CD 4093.
Also some low pass filtering (a small capacitor between the phototransistor's output and ground) will help.
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is offline
Old 12th September 2007, 07:55 PM   (permalink)
If you use a microcontroller for your counter, software filtering could eliminate the multiple transition problem.
Ron (aka Rube)
Roff is offline
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) smilen Micro Controllers 15 21st November 2005 10:23 AM
Help me on basketball's game clock and shot clock! syaw_007 Electronic Projects Design/Ideas/Reviews 1 6th September 2004 10:50 PM
