Old 12th September 2007, 07:08 PM   (permalink)
Default LED MOSFET suggestions?
Hello all,
I'm planning on driving an LCD backlight (array of 6 LEDs internally) with a MOSFET and PWM from a PIC microcontroller, so it can be dimmed for day and night operation. PIC sends PWM to the MOSFET's gate, MOSFET rapidly switches either high side or low side to create a dimmer effect controlled by the PIC.
Given the thousands and thousands of MOSFETs out there, can anyone suggest a part number or family (surface mount only please) that might fit this bill, or at least narrow my search?
Thanks,
Ray
rackley is offline
Old 13th September 2007, 01:50 AM   (permalink)
First of all, you want a "logic" MOSFET. This means that you can switch it directly from the PIC output (usually with a series resistor).
The simplest circuit will switch the low side of the LEDs and use an N-channel device. This is good, because N-channel is cheaper for a given spec.
For a backlight, I'm guessing that you need 100 mA at 5V. If this is a cost sensitive commercial product, I would start with the Digikey selection guides. Be sure to allow plenty of margin.
For hobby, margin is less important. The 2N7002 is available in a lot of places for 5 cents and up. I have excellent results with DPI4Parts on ebay. You'll pay $5.15 for 100 of them. If your backlight needs more than about 75 mA, use two or in parallel.
mneary is offline
P channel FETs vs N channel FETs for LED Matrix applications ?? tdg8934 General Electronics Chat 3 9th September 2007 06:17 PM
P-Channel Power Mosfet Help behrendfry General Electronics Chat 2 27th October 2005 02:12 PM
MOSFET Relay problem guilio_2000 General Electronics Chat 16 10th August 2004 05:33 PM
Here is a list of semiconductor prefixes. TPS Datasheet/Parts Requests 0 21st December 2003 08:24 PM
Identify Semiconductors by prefixes mixos Datasheet/Parts Requests 0 10th December 2003 07:56 PM
