Old 12th September 2007, 09:30 AM   (permalink)
Question Simplest possible negative supply
Hello all
I'm building a portable sound amplifier circuit which is powered by a single 9V battery. However, the TL072s in the circuit need some sort of +/- supply. I was thinking about trying out a MAX232 or similar RS232 line driver, which makes +/- 10V unregulated power, but my question is:
Do you know of a better/simpler/cheaper/smaller (physically) solution to this problem?
The current I need will probably be in the tens of milliamps at most, so the demands on the supply aren't too great. Regulation would be nice, though.
I ask this question both because of ignorance, but also because the ingenuity of other people often surprises me.
I hope you can help.
Pax Writer is offline
Old 12th September 2007, 09:37 AM   (permalink)
Generate a split supply using two simple resistors, there are examples all other the net, and all over these forums - this will give you +/-4.5V.
Old 12th September 2007, 10:17 AM   (permalink)
Maxim have charge pump DC-DC converters suitable for your application. The ICL7660 has been commonly used to generate a negative supply for an op-amp. It can deliver 10 ma max. http://datasheets.maxim-ic.com/en/ds...60-MAX1044.pdf
You'll find newer solutions at maxim-ic.com
eng1 is offline
Old 12th September 2007, 10:43 AM   (permalink)
TL072 supports to single supply arrangement so you can directly give supply from battery.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 12th September 2007, 10:47 AM   (permalink)
Pax Writer, what voltage swing do you expect at the output of the TL072?
eng1 is offline
Old 12th September 2007, 01:01 PM   (permalink)
ANY opamp can be powered from a single supply.
An opamp's supply doesn't need to be regulated.
Here is an opamp that is biased at half the supply voltage and has input and output capacitor coupling so it can use a single supply:
audioguru is offline
Old 12th September 2007, 10:10 PM   (permalink)
@eng1: Ehm, honestly I'm not quite sure. The TL072s in my circuit are only preamps, and so I don't expect a very big voltage swing. No more than 2-4 volts maybe.
The final stage will drive a set of headphones.
Old 12th September 2007, 10:13 PM   (permalink)
@Audioguru: Thanks for the great illustration. I definately need to read more into the finer points of op amps. Can you shortly explain why the output capacitor couplings?
Old 12th September 2007, 10:34 PM   (permalink)
They are DC blocking capacitors or AC coupling capacitors; without them the output signal will have half the supply voltage DC superimposed on it.
Screen name: Aloone_Jonez
Hero999 is offline
opamp audio mixer - single supply fvnktion General Electronics Chat 7 11th July 2007 08:16 PM
How to generate Negative powser supply from +5V ? octal Electronic Projects Design/Ideas/Reviews 4 21st January 2007 04:39 AM
create component multisim8 max1000000 General Electronics Chat 1 4th December 2006 04:02 AM
how can i produce a negative supply voltage from +12V? spyghost Electronic Projects Design/Ideas/Reviews 15 3rd June 2004 07:05 AM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 02:10 AM
