Hi I have this preamp circuit connected to my amplifier. Can somebody tell me how to increase the BASS of this preamp? What changes do I have to do?
Thanks |
This is a standard Baxandall tone controls circuit that has a range of boost or cut of about 20dB which is planty.
Are the pots linear? Is the source impedance very low like from the output of another opamp? Is the load impedance 10k or higher?
Uncle $crooge |
Hi audioguru thanks for viewing my circuit.
The pots are I don't know whether they are linear or not. I'm giving inputs from another old radio.How can I measure the source impedance.? And the load impedence you mean the power amp impedence? Can I measure that also from a DMM? Thanks. |
--- The days of the digital watch are numbered. --- |
Hi kchriste thanks for your input.
If there is no load then how can I determine the audio level is half way mark? I'm taking the signal from line out jacks.You mean to connect a Variable resister to this line out jack? I have only DMM. |
hi Suraji
I think the jack you have in your old readio is for headphone, or any xtra speakers. The impedance of the normal speaker and the head phone is 8 or 16 ohm. So you can consider this as a low impedance circuit. Normally the microphone( electret) and the pickups have the higher input impedence. My advice you can consider this us a low impedance device |
This is the socket I have in my old radio.I'm taking signal from it.Its printed "line out" left & right.If I change the volume level it wont change because its there as line outs.
Only thing I need to verify my source impedance & the load impedance. Kchristie gave a solution but I have only DMM & a 100K variable resister. Can I measure them with a DMM? |
Bit puzzled as to why the two resistors creating the spilt supply are different values?, you should also have a decoupling capacitor from their junction down to chassis. |
The split supply voltage is slightly higher than half the total supply voltage because the TL07x opamp has an output that is a little better going high than it goes low. It doesn't make much difference but it looks more symmetrical to see it clipping on a 'scope.
Uncle $crooge |
Ok thanks for the replies I satisfied with the current quality because I don't have special equipments to measure the impedance.I'm worry about that.
Also for my speaker wires I used very thin cheap wires.After changing that also I got a good quality. Is there any method to give signal to this preamp other than giving from an old radio? How do I confirm that current input signal is weak or good? |
The tone control circuit should be fed from the extremely low output impedance of an opamp. Then the new opamp can be fed audio from any audio source.
Does your radio or speaker have poor low frequency response that requires the bass control to boost the bass? My home speakers are flat to 55 Hz. I made a bass boost circuit that boosts 30Hz by 10dB (10 times the power). Then they sound like a sub-woofer is with them but I don't have a sub-woofer at home, only in my car.
Uncle $crooge |
(permalink) | |||
(permalink) | |||
Uncle $crooge |
OK thanks audioguru I'll make a preamp with TL 072 so I can give inputs from many devices.
Now when I give inputs from computer it will give some quality. when I give inputs from a CD player it will give another quality. So after adding the new preamp it will be all right I believe. Thanks a lot audioguru. |
Add the second opamp like this:
Uncle $crooge |
| Audioguru Please See My Simple PreAmp Circuit | Gayan Soyza | General Electronics Chat | 11 | 8th May 2007 02:58 AM |
| Bass guitar power amplifier project | j0nny_s | Electronic Projects Design/Ideas/Reviews | 13 | 21st October 2006 09:00 PM |
| preamp to amp | crivoli | Electronic Projects Design/Ideas/Reviews | 9 | 23rd May 2006 04:14 AM |
| need drawing for 2 bass speakers | danielsmusic | Electronic Projects Design/Ideas/Reviews | 10 | 19th September 2005 08:20 PM |
| Increase the range of RF transmitter/receiver | letsrelaythat | Electronic Projects Design/Ideas/Reviews | 19 | 5th July 2004 04:44 PM |
