Hello, I am wanting to make a super safe, nimh/nicd smart battery charger. After looking around, I've decided to use the DS2714 chip for my design. If you have any other chip suggestions, please let me know. http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5297 I think I pretty much have the schematic of how to get the DS2714 working, except for the current source. I found no information on the current source in the data sheet, except "current source". Does anyone know what current rating my current source should be? Also, I will be using a regulated 5V to power this charger, how can I turn that into a current source? Thanks! | |
hi Fred, Have you checked Maxims application notes? http://search.maxim-ic.com/search?ie...h/search3.xcgi Whats the voltage/AHr capacity you want to charge? You can configure a 7805 or LM317 as a current source.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:21 PM. | |
The current source in the datasheet is 2A. it charges each of 4 cells for 1/2 a second each 2 seconds, minus a small amout of time where each cell is tested.
hi, as 'agu' points out a 2Amp current source is required for the 4 cell charger in the application data. A 7805/L317 isnt upto the job, you require a similair regulator but with a minimum continous current of say 3amps. Extract from data sheet.
Thanks for the information guys! I didn't see that 2A in the datasheet anywhere, I must have been blind. Unfortunately, my source power has a maximum current of 500mA. Would that work with this chip (just take 4x as long) or do I need a totally new chip? Any recommendations? Thanks again! Last edited by Fred.Amoson; 9th September 2007 at 04:27 PM. | |
| | #6 |
The IC is a fast charger for individual Ni-MH cells. It times out after a max of 10 hours. 2500mAh AA cells need 20 hours or more at 500mA/4.
| | #7 |
How many cells do you need to charge? If it's just one then you could use a switching regulator for your current source and get 1A@2V from 500mA from 5V@500mA which would cut your charging time in half. You really need a much higher current power supply, I'd recommend a PC power supply which can supply a lot of current and is quite cheap to.
| battery, charger, current, ds2714, source |
| Current limiter on a battery charger | johndale | General Electronics Chat | 5 | 31st July 2009 02:38 AM |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 06:17 PM |
| headlight current source. battery or alternator ? | manoj.patil.1974 | Electronic Projects Design/Ideas/Reviews | 8 | 3rd May 2007 01:22 PM |
| Micro Controlled Battery Charger | PeterDove | Micro Controllers | 2 | 15th December 2006 01:52 PM |
| Battery charger for a special pack | Magnus Wedberg | General Electronics Chat | 4 | 4th February 2005 06:39 AM |
