Old 31st August 2007, 12:45 AM   #1
Default Wirewound Resistors in RC filters
So if I had a 1kHz RC filter, do you think I could use a chip wirewound resistor? 1kHz is pretty low and if anything I *think* the inductance *might* somehow help the filtering. At the very least I don't think it would have any negative impact.
Opinions?
dknguyen is offline
Old 31st August 2007, 12:55 AM   #2
Won't hurt but you're right it's not likley to help either, unless you can find wirewound resistors designed with high inductance in mind.
straight answer, har har."
Sceadwian is offline
Old 31st August 2007, 08:34 AM   #3
Opinions?
I fear the chip wire wound resistors are wound in a fasion the inductance is cancelled -- Halve the wire length by folding back at the centre - after winding the doule wire- solder the leads
instead you can staight go for chip inductors and call it LC filter
Regards,
Sarma.
mvs sarma is offline
Old 31st August 2007, 05:40 PM   #4
Opinions?
If this is a low pass with the L in series with the R, it will help roll off the response. However, if The ratio of L/R is much smaller than R*C then, your little bit of "L" is really not doing much. I imagine that the parasitic L of a wirewound chip resistor is relatively small.
Optikon is offline
Old 31st August 2007, 11:41 PM   #5
What size are the wirewound resistors?
I've seen some huge wire wound reostats wound on iron formers that are so inductive that they draw a huge arc from a 24V supply when they are disconnected.
if I know the answer.
Hero999 is offline
filters, resistors, wirewound
Resistors Marks256 General Electronics Chat 57 16th May 2009 11:22 PM
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 28th August 2007 12:06 AM
7447 with resistors Overclocked General Electronics Chat 5 27th January 2007 01:30 PM
Electric Heater using 330 Ohm Resistors Electric Rain Electronic Projects Design/Ideas/Reviews 20 14th January 2005 09:54 PM
band pass filters aidanbre Electronic Projects Design/Ideas/Reviews 1 29th November 2002 07:43 AM
