| I wanting to put together a temp controlled switch using a k type thermocouple to simply turn a relay on and off with the set temp is reached. Any help or suggestions would be great | |
| As it is our nature to try and understand the greater context, I wonder: - why use a K type thermocouple rather than a thermistor or semiconductor temperature sensor? The thermocouple requires a bit more interface circuitry and so is not the most convenient choice. A K type is not the most accurate choice either so the alternatives, which are not particularly accurate either may be considerably more convenient. - while a relay is easy to use, it is also slow, noisy, less power-efficient, larger and perhaps even costlier than a semiconductor solution so, why use a relay? However, to answer your question as originally asked, start with an accurate thermocouple interface: http://www.analog.com/en/prod/0,,764_811_AD595,00.html http://www.sparkfun.com/commerce/pro...roducts_id=306 then wire the output of this to a comparator circuit http://home.cogeco.ca/~rpaisley4/Comparators.html and use a potentiometer in the second input of the comparator to set your desired switching point. Then use the output voltage of the comparator to drive a relay: http://www.uoguelph.ca/~antoon/gadge...ys/relays.html
__________________ RadioRon | |
Thanks for a well explained link [Comparators.html], I will point OP's asking about Comparators to that site. Saves constantly repeating the same answers. Eric | ||
And why should one even consider controlling an oven with anything other that a contactor (relay)? This is all rhetorical .......... of cause. | ||
| Some thermistors will work at those sorts of temperatures. I would use a small light bulb as a thermistor as it's pretty cheap and reliable, I'd go for a 5W 240V bulb as it'll have a higher resistance that's easier to measure than a 12V bulb. Also, it's the origional poster's fault for not providing enough information.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 26th August 2007 at 10:00 PM. | |
| Button Debounce Coding help | Suraj143 | Micro Controllers | 25 | 4th August 2007 10:49 AM |
| Computer Controlled Router Monitor (switch) | dannix | General Electronics Chat | 2 | 16th July 2007 08:21 PM |
| computer controlled power switch | Michael Daly | Electronic Projects Design/Ideas/Reviews | 2 | 25th June 2007 07:14 PM |
| PIC Switch Management Techniques | Mike, K8LH | Micro Controllers | 2 | 28th September 2006 01:33 PM |
| how to build a voltage controlled switch | terramir | General Electronics Chat | 9 | 24th May 2004 07:23 AM |
