| (sorry for the bad title, but I'm a bit tired.) Today I picked up a LCD screen for an overhead projector -- it's transmissive so light can pass through projected on a wall/screen/etc. Basically a poor man's digital projector. Did some research; it's capable of 800x600 @ 32 bit color. Pretty decent. Then I got an idea -- use it inside my computer case, where I can see the display while having a backdrop of computer components. Sat down, ripped the LCD and driver board out of the case, tested -- worked fine on supplied adapter. Fitted the LCD to the side of my case + glass, tested LCD with supplied adapter -- worked fine. Solder a +12V line and GND from my computer's PSU connector onto the board in place of the supplied +12V adapter -- no luck. There's a 7805 on the driver that overheats and goes into thermal protect. I can't figure out why the LCD just doesn't work off of my computer supply opposed to the supplied PSU. Both read within a hundredth of a volt (12.24V). Is it that the PSU brick that came with the LCD drops voltage when something is connected more so than my computer's supply? This one's got me stumped. Any ideas? Thanks!
__________________ -Ian | |
| Hi, Supplied adapter appears cheaper and the dropped voltage helps 7805 to have in-out differential less then when you use computer PSU. the 12V remains so, the the 5v Regulator heats up. because of almost 7V across input and output of the regulator. perhaps if you pre regulate to 9V and then supply to LCD it might work One way it is better that you save the power of computer by using external adopter for the LCD part. | |
And as for power coming from my computer, that's not a problem. I invested in a system that can put out 20A of current on two 12V lines (40A total 12V). Thanks, and I'll see if I can post some pics of the board to make things a little more clear.
__________________ -Ian | ||
| | (permalink) | ||
I think your computer supply should have a regulated +5V lead you could use and skip the 7805 entirely, but get some confirmation on that from someone without so much lager in them before hooking it up and cooking something. Sounds like a neat project. Good luck! Torben | |||
Using the display's own power supply, measure the voltage between the PC's ground and the display's adapter's negative lead. If you get more than a few milivolts you can't connect them together. The display may use an split supply, and so the display's power "-v" is not ground. In that case you can't use the PC's supply to power the display, unless you add an insulating DC/DC converter to "float" the display.
__________________ E Cerfoglio Buenos Aires Argentina | ||
EDIT: Just checked the voltage under load, it drops to 7.22 volts. I can use the computer's +12 line as the +V supply and the 5v line as ground. It should work out to 7.2 volts because my computer +12 supply is a hair over 12v. EDIT 2: Turns out the board has a switching regulator on it to provide 3.3 and 5v, but not much 5v. I've never worked with a switching power supply before, so where does that put me?
__________________ -Ian Last edited by theinfamousbob; 16th August 2007 at 08:42 PM. | ||
| OK I'm just giving up on the power issue, and took the advice to put the original power supply in the case. It's pretty hacked together, but here it is: http://hs.facebook.com/album.php?aid...&id=1436340228 Enjoy! (I need to buy white lights soon.)
| Hi, Just a thought. If the lcd uses a 7805 to drop the incoming power to 5v, can't you just power it with a +5v supply from your pc's psu? the feed to floppy, HDD and CDROM all have a +5v feed.
__________________ 'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein | |
this case may perhaps be comparable to external modems of yesterdays, with used to come with a step down transformer. Having said all this may i ask for make and model number of the LCD display device that you bought? Sarma | ||
| I knew someone who did this using an old laptop and overhead projector he purchased from eBay. It worked surprisingly well too.
The LCD has no built-in backlight or backing, so I had to create one (see pics in previous post). My guess is that the 12V computer line is just too much for the switching regulator or something similar. I could try wiring in the 5V line in place of the 7805, but I'm still a little nervous. I'll have to test it in an older computer instead of my nice one. Thanks!
| I understand your problem. but i don't find any obvious reason that the LCD SHARP model accepts 12V from a wall adopter and NOT from a 12 V battery of laptop or its adopter? genrally lap tops working of around 18V battery and when adopter is parallely connected, the voltage may be around 18+2 =20V. the LCD panel may have a high voltage sense, and thus perhaps refusing to accept the external supply from the laptop. this is of course wild imagination - so that you may analyze and act on situation regards Sarma Last edited by mvs sarma; 19th August 2007 at 08:00 PM. | |
| Thanks for all your help! I'm going to see if I can dismantle and poke around the transformer. Hopefully that'll shed some light on this. Thanks again!
| Fixed it. Don't ask me why, but when I cut a power cord that fit the jack, stripped it and used a computer +12 supply, the thing worked magically. I'm guessing that there was something wrong with just soldering to the board; maybe a missed PCB layer or something. Plus, I salvaged a backlight almost the same size out of an old laptop! Thanks for your help everyone, will post pics as soon as it's all done! -Infamous
| Hai, CONGRATS for the success that is nice and you are now able to feed from laptop bty. all the best Sarma | |
| Power up problem 16f870 | hotrodhed120 | Micro Controllers | 2 | 20th April 2007 10:51 PM |
| Problem Calculating Power in Flyback Converters | alisarhangpour | Electronic Projects Design/Ideas/Reviews | 2 | 11th April 2007 05:45 PM |
| Newbie, please help with power problem | techieguy | Micro Controllers | 11 | 25th July 2005 01:07 PM |
| Micro / Car / Power problem | TKS | Micro Controllers | 6 | 28th April 2005 02:29 PM |
| What is the difference between Va and watts. | goodpickles | General Electronics Chat | 10 | 8th September 2004 10:04 AM |
