Old 11th August 2007, 09:56 AM   (permalink)
Question Is this scope any good?
I want to buy a scope, but I know nothing about them
does anyone know if this scope would be anygood?
many thanks
bitem2k is offline
Old 11th August 2007, 10:16 AM   (permalink)
To be honest, computer scopes like that are more a toy than a real scope, they certainly have their uses, but NOT as a replacement for a real scope.
Old 11th August 2007, 10:25 AM   (permalink)
Im a poor student!
I cant afford hundreds of £ for a 'proper' scope.
do you think it might be a reasonable first scope?
bitem2k is offline
Old 11th August 2007, 10:41 AM   (permalink)
Did you read the specs?
Real-time sampling: 75MS/s one channel, 150MS/s using two channels
What crap is that: higher sampling rate with more channels
Or it's always 75MS/s per channel
Or it's the other way 150MS/s one channel and 75MS/s two channels
and further
Vertical resolution: 8bits/channel
Is that all
Use a PIC and send serial data to the PC and you will have better results!!
Since those guys can't write decent specs I would never buy it !!!
Check the NI Site they have (more or less) cheap USB DAQ pads!
Good, very good stuff...
http://sine.ni.com/nifn/cds/view/mai...id/1036/ap/daq
mcs51mc is offline
Old 11th August 2007, 10:42 AM   (permalink)
Originally Posted by bitem2k
Im a poor student!
Off topic : £ what England are you in??
mcs51mc is offline
Old 11th August 2007, 10:49 AM   (permalink)
Im a poor student!
hi bitem,
The spec looks fine, the 8bit [255 increments] Y axis is a little limited.
The advantage of this type of scope is its small footprint and portability and the fact you can store screen shots.
Also with care it will last a long time.
What's the spec of your PC?
Eric
EDIT:
follow up to hero's Q, what projects do you want to scope??
ericgibbs is offline
Well I wouldn't buy it because it doesn't support the operating system I use.
I suppose it's better than no scope at all but it depends on what you want to use it for.
Screen name: Aloone_Jonez
Hero999 is offline
Old 11th August 2007, 11:49 AM   (permalink)
Im a poor student!
No, you could buy a second hand real scope for less money!.
It's something you buy AS WELL as a real scope, not instead of.
Old 11th August 2007, 11:55 AM   (permalink)
and further
Is that all
Originally Posted by ericgibbs
hi bitem,
You both seem to disagree about the specs.
Would 75ms/s only per channel be bad?
Do you mean something like this device ?
Whats the difference between this and a PC scope?
I’m sorry, I have no idea what you mean.
hi bitem,
Im just learning how to program the Pic at the moment, so I want to use peripherals such as the PWM module, and shortly serial transmission, etc.
My pc:
Intel 3.4Ghz processor
2048MB Matched pair Gaming ram
300GB SATAHarddrive
bitem2k is offline
Old 11th August 2007, 12:11 PM   (permalink)
They aren't disagreeing about the scpecs. They're saying different things about different parts of the specification.
ericgibbs iss saying that 8-bit vertical resolution is poor and mcs51mc is saying that the sample rate might go down if you use more channels.
You appear to be getting stressed (this is indicated by your decision to use bold text), there's no need to get stressed, no one's arguing or having a go at you.
Hero999 is offline
Old 11th August 2007, 01:15 PM   (permalink)
I agree, real scope first.
And Ebay seems to have a ton of them in the US. I know there is a UK ebay, I would look on there. You will be able to get a used scope for the same price range, maybe less.
mramos1 is offline
Old 11th August 2007, 01:31 PM   (permalink)
hi bitem,
If you want to examine signals like RS232 serial then the USB scope would easily get the job done.
It would also be OK upto 20mHz[clk] to examine the PIC's PWM output.
Most of the digital voltages will be in the order of 5V and the RS232 say +/-15Vmax.
If you wanted to measure very fast edges/pulses you would get some fall off in performance.
The reason I asked about your PC's spec was just to check that the PC may limit the performance of the USB scope,
the PC spec you have will give no problems.
If you had a steam driven MMX200mHz, running Win98 then this could have given problems.
You can buy S/H 'electronic' scopes, if you decide to go that way, check yellow pages for companies that resell S/H equipment,
also try a local industrial auctioneers.
You can get first class equipment for a good price. Always get a pair of good quality 1/*10 probes.
May I ask which town/county you are in?
Eric
Old 11th August 2007, 05:20 PM   (permalink)
No not getting stressed, I dont know what would give you that idea!
Just emboldening my responses to more easily differentiate between other peoples quotes and my responses!
HerbertMunch is offline
Old 11th August 2007, 05:23 PM   (permalink)
hi bitem,
Eric
Canterbury, Kent
Old 11th August 2007, 05:26 PM   (permalink)
Whats the difference between a scope and a DAQ?
Daq i.e (http://sine.ni.com/nips/cds/view/p/lang/en/nid/14604)
would this be more suitable?
many thanks (dont worry, Im not getting angry/stressed! )
Is $20 a good price for a P16PRO40 Programmer? Mike, K8LH Micro Controllers 11 5th July 2005 02:19 PM
Oscilloscope and grounding Cifrocco General Electronics Chat 19 1st June 2005 08:46 AM
Where to get Good Power Supplies? Megamox General Electronics Chat 10 26th May 2005 12:06 AM
Good intro to PICs... pwollner Micro Controllers 1 18th February 2004 03:37 AM
Need a Good and easy project of Cotrol !!! gravityforu Electronic Projects Design/Ideas/Reviews 1 12th December 2002 03:43 PM
