Old 7th August 2007, 03:50 AM   (permalink)
Default how to get <1V by using regulator
i m using LM317 regulator, may i know that what kind of method i can use in order to get voltage <1, since for the data sheet write that the minimum voltage range will be 1.25V..
thanks...
meera83 is offline
Old 7th August 2007, 04:56 AM   (permalink)
Using that part there is no method that I know of. You might have more luck with an adjustable LDO regulator from Micrel, National, TI, or Maxim.
Papabravo is offline
Old 7th August 2007, 09:40 AM   (permalink)
You simply require a negative supply as well, so the bottom of the regulator is below zero volts. You're basically moving the zero reference point - it's a technique used for PSU's that vary right down to zero volts.
Old 7th August 2007, 09:47 AM   (permalink)
You can use a DC/DC converter with a voltage reference. It's a trick someone showed me on here about a week ago. Look for a post by me about DC/DC converters and it will have the link. We used it at work to get down to 0.2V regulated output at 50% efficiency from 3V in IIRC.
speakerguy79 is offline
Old 7th August 2007, 02:25 PM   (permalink)
thanks...
just put Two diodes in series with the output. You will lose a little bit of stability, But the voltage drop across these diodes will allow you to get Close to Zero volts out.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 7th August 2007, 05:59 PM   (permalink)
This is how I'd do it anyway.
http://www.electro-tech-online.com/a...-15v-lm317.pdf
You do need a negitive supply but this is noramally easy as you're probably running it from the mains or a PC power supply; if not then you can build a negitive supply from a 555 timer.
Screen name: Aloone_Jonez
Hero999 is offline
Old 7th August 2007, 06:22 PM   (permalink)
Is this a <1V signal? Or <1V power?
dknguyen is offline
Old 7th August 2007, 07:03 PM   (permalink)
That's true, if you want a signal then use an LM7805 and a potential divider followed by a non-inverting buffer.
Hero999 is offline
Old 8th August 2007, 01:38 AM   (permalink)
i need <1V for power supply and also signal...
how can i get negative power supply?if i use 9V battery, then the voltage will become 0-9V...how to change it become negative voltage?
meera83 is offline
Old 8th August 2007, 05:44 AM   (permalink)
How much current do you need? If it's less than about 200 mA, I would use the obsolete and extremely cheap LM324 (or TL072) driving a 2N2222 in emitter follower configuration.
mneary is offline
Old 8th August 2007, 05:53 AM   (permalink)
The output of an old LM324 quad opamp or an old LM358 dual opamp goes to ground if it has a single supply voltage.
The output of a TL07x does not go to ground, it goes to about 1V above ground if it has a single supply voltage. So adding an emitter-follower will not produce an output down to ground.
audioguru is offline
Old 8th August 2007, 06:10 AM   (permalink)
Although the TL07x won't sink useful current closer than 1V from ground, it stops sourcing as well. This meets the 1V output requirement. It might need a pull-down resistor, though.
mneary is offline
Old 8th August 2007, 09:12 PM   (permalink)
An op-amp that can swing to 0V won't be any help in the circuit I posted as the ADJ pin needs to be held at -0.25V for an output of 1V so a negitive supply is unavoidable.
Hero999 is offline
Old 9th August 2007, 02:06 PM   (permalink)
thanks...
try to use a single cell for -ve refby connrcting its +ve to ground and the lm317 can now be referred to -1.5V -- thus minimum can to to zero-- a possible method for explanation only is attached here - this is with courtesy of National semi datasheet info--
Sarma
mvs sarma is offline
Old 9th August 2007, 05:03 PM   (permalink)
I can see you do not have a negative voltage so: see attached file.
You must choose the correct op-amp. Most op-amps will not work with their inputs near the same voltage as the supply pins. ( If the power supply is 0 to 12 volts then many will not work if either input is less then 2 volts or more than 10 volts.) You need to look for an op-amp that has a “common mode input voltage” that includes the negative supply. There are some amps like that, you might start out looking at MicroChip for low voltage op-amps.
ronsimpson is offline
Voltage Regulator Todd Electronic Projects Design/Ideas/Reviews 19 30th May 2007 11:55 PM
Switching regulator for dev board Blueteeth General Electronics Chat 10 5th January 2007 10:31 AM
Convert voltage regulator to constant current regulator? goldserve Electronic Projects Design/Ideas/Reviews 10 11th September 2006 06:39 AM
12vdc to 6vdc regulator kami Electronic Projects Design/Ideas/Reviews 2 15th April 2004 10:38 PM
Please Help. How connect Pass Transistors in (-) Regulator? hamfiles Electronic Projects Design/Ideas/Reviews 2 23rd June 2003 07:27 PM
