Old 6th August 2007, 10:35 PM   #1
Default Interesting 7555 circuit.
Can anyone guess what it does?
if I know the answer.
Hero999 is offline
Old 6th August 2007, 11:30 PM   #2
It's an oscillator.
When the output goes high, the voltage at pins 2 & 6 rises at the rate set by the L/R time constant. When it reaches the upper threshold, the output goes low so the voltage at 2 & 6 decays. When it reaches the lower threshold the output goes high again.
Len
ljcox is offline
Old 7th August 2007, 06:16 PM   #3
I was bord and started plaing around with components.
I am aware that RC oscillators exist but I've never seen any LR oscillators so I decided to design one. However, I don't see how this is any use, other than for determining the value of a large value inductor using a frequency counter.
Hero999 is offline
Old 8th August 2007, 02:32 AM   #4
Yes, capacitors are cheaper than inductors.
Yes, it could be used as a crude inductance measuring set.
Len
ljcox is offline
Old 22nd February 2009, 05:39 PM   #5
Sorry for posting on a tread that low, but did you try this circuit?
I am asking this because I am at the start of various SMPS experiments
and I need to know how an inductor behaves when loaded with large currents.
Any idea if output frequency/period will be linearly proportional to inductor value?
Regards
adash is offline
Old 22nd February 2009, 08:23 PM   #6
It works, there are much better ways to build an oscillator though.
Hero999 is offline
Old 22nd February 2009, 09:35 PM   #7
Did you take a look at the voltage waveforms?
I tried simulating it in LTSPICE but voltage on 2+6 pin node swings from gnd to supply voltage, while in a normal 555 circuit it should swing from 33% to 66% of Vcc.
I was thinking about measuring an inductance, not about constructing a generic oscillator with it.
Regards:
Dimitar
adash is offline
Old 22nd February 2009, 10:25 PM   #8
I would have thought pin 6 would swing from 33% to 66%.
Going from the 7555's datasheet the frequency should be approximately equal to the following formula:
F=\frac{1.1R}{L}
Hero999 is offline
Old 20th July 2009, 07:18 PM   #9
Did you ever try this with a Programmable Unijuction?
Kinarfi
kinarfi is offline
Old 20th July 2009, 07:32 PM   #10
No but I'm sure it's possible with a programmable unijunction.
You can build an LR oscillator using a comparator or just transistors. There's little point in building an RL oscillator, apart from determining the value of an unknown inductor.
Hero999 is offline
Old 21st July 2009, 12:49 AM   #11
I'm sure you're right, but every experiment teaches you something, and of course, so does every failure, if you can figure out what you learned I guess I just gotta see if I can do it.
kinarfi is offline
7555, circuit, interesting
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 4 23rd August 2009 05:38 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 13 19th February 2009 07:27 AM
I need help in designing a circuit chefach Electronic Projects Design/Ideas/Reviews 13 27th September 2007 12:15 PM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 11:46 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 04:07 AM
