Once you start using this function, you'll find softwares like Eagle the best for PCBs as it is very good at this. Making PCB from schematic is really easy and reduces errors than making one from scratch without annotation function You are not at all giving me a hard time
__________________ "There is no way to peace, peace is the way!" Last edited by kinjalgp; 23rd July 2007 at 11:53 PM. | ||
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
__________________ "There is no way to peace, peace is the way!" | ||
| Having the schematic capture feed the PCB layout is a huge time and error-saver, even for the hobbiest. Granted if you're a hobbiest making a small board with just a few components then almost any PCB layout program will do, but as a hobbiest I have several boards with *hundreds* of pins even though they have relatively few components. Also, as we're all busy in our real lives(tm), saving time when doing one's hobby is a damn fine idea :-) I have previously used Protel which is great to use but has now totally outgrown the reach of any hobbiest and even many small companies. Now I use ExpressPCB because it is hands-down the easiest tool to use. Eagle's UI sucks major rocks, as do the UIs of most of the others mentioned in this thread (I've tried lots of them!) I've happily used ExpressPCB to create artwork for a single-sided PCB which I then etched at home... including one with 400+ holes (eek! I hate drilling!) This allows me to create initial prototypes without need to go straight to ExpressPCB for manufacturing. Now that I've got the design right, I'll add double-sided traces to replace the links and tidy the layout, then send it off to ExpressPCB. Hope this helps, P. (aka pantoine on Sparkfun forums) | |
| Sounds like ExpressPCB is worth a try. I have used Eagle enough to not mind the UI too much but I am still unhappy with the library search and the part editing could be better. I have used Eagle enough that I do not mind the UI but I find it difficult to teach to others. So I will give ExpressPCB a try. At this point I am going to go off topic a bit and talk about board making. Quote:
Last winter I discovered the local high school where I volunteer has a milling machine. Since then I have been using it and PCB-GCODE on Eagle to generate NC files. Works great and the holes are very neat. If I switch I will have to figure out how to generate the code to drill the holes. Maybe some EXECLON to GCODE tool. The machine drilled holes makes alignment somewhat easier. I do some 2 sided boards but etch one side at a time. The other is covered with box tape.
| Does PC express have a way of converting a schematic into a PC board layout for printing? I have been horsing around with eagle and it is a pain. I cant get a schematic converted to a board layout. | |
You can't expect that Eagle/any other software will do all the neat placement for you and even if it does...it is not at all efficient. For testing what I am trying to say just try out the "auto-place.ulp" in Eagle. No software is written yet to replace human brain
__________________ "There is no way to peace, peace is the way!" Last edited by kinjalgp; 24th July 2007 at 03:46 AM. | ||
| Wow! Thanks a lot guys.Plenty replies.So I planned to work with EAGLE lite edition. I have Express PCB too but I didn't try yet. | |
| Its Express PC, lol. I guess I will horse around with Eagle a bit more and see. I tried the board command but nothing happens, just a blank board appears? | |
Use your mouse roller for pan zooming.
__________________ "There is no way to peace, peace is the way!" Last edited by kinjalgp; 24th July 2007 at 04:43 AM. | ||
| Ill give that a try, Thanks for the help kinjalgp. | |
| Placing the components and routing the signals as much art as science. It is best to finish the board and then go away for a day or two. When you come back you can often see ways to improve it. It helps to run through a tutorial or two. Observations: DRC (Design Rule Check) is used to check you layout for problems. It checks for clearance between traces and pads. The default is 8 mils. It is also where you can change the restring value which determines how large you pads will be. The default is 25%. I often use 35% which provides larger pads. Some connectors will not allow you to up the restring value There is no good reason to use 8 mil clearance if your board will allow 10 or more. I like to route the board at 8 and change it to 10 whien I am finished. DRC will show me where there are clearance problems. Where possible I fix them to achieve 10 mil clearance. The ones I can not I leave alone. Then I set the clearance back to 8 and run DRC again to make the unfixable errors go away. I now have a board with 10 mil clearance execpt in a few places where it is not possible. The default trace width is .016. Execpt for lines that carry current (power and gnd) I like to use .012 or .010 inch traces. Neatness counts.
| my first PCB layout help | bababui | General Electronics Chat | 7 | 3rd May 2007 10:28 AM |
| CNC software for PCB drilling | 3v0 | General Electronics Chat | 5 | 28th February 2007 11:14 PM |
| PCB Designing Software | pixnum | General Electronics Chat | 6 | 27th January 2007 06:19 PM |
| software for PCB LAYOUT | garg29 | General Electronics Chat | 2 | 24th April 2005 07:20 PM |
| Breadboard layout software | gjpollitt | General Electronics Chat | 3 | 11th January 2004 09:42 AM |
