+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 33
Thread: Current limiting Help PLZ
  1. #1
    Frosty_47 Good Frosty_47 Good
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Smile Current limiting Help PLZ
    Hello every one!
    I am trying to limit the current down to anywhere between 2.5A-3A. Basically, I like to limit the current to my Pettier Cooler that I like to use to chill my over clocked CPU. I don't want to use a resistor because that would be to inefficient and a lot of heat would be generated. I would like to use LM350 regulator to limit the current. I found this in the datasheet...
    Will that work for LM350 as well ? If it works, than the 0.4Ohm resistor should only dissipate around 3.6 Watts + 3.75 Watt regulator dissipation. So the total heat dissipation should be around 7.35 Watts than ?. If my calculations are accurate than this is much better than using a resistor to limit the current. Or is it ?
    Thanks,
    Andrew Frost
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    You would waste exactly the same amount of heat. The only advantage of using a constant current source is that the current will stay steady if the input voltage varies.
    If you wish to be efficient, you must use a current mode switching regulator.
  3. #3
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Smile
    The peltier I have is 150W so at 12V input it will consume 12.5Amps. In order to limit the current to 3 Amps with a resistor, I would have to use a 3 Ohm resistor. That means the resistor would have to dissipate 9 Watts. I do want a constant current source though. I do no like to go with switching due to noise issues and inexperience. I don't like to go with a single resistor either. So will this circuit limit the current to 3A?
    Thanks!
  4. #4
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Default mmmm switching regulators...
    On the other thought, Switching regulator will definitely be of much higher efficiency but, I never dealt with switching before so it might be little bit scary for me. Although I must admit, that if I never start, than I will never get any experience with switching regs. If I were to implement switching regulator instead, will it cause any problems with my PSU due to noise? Will I have to add noise filters?
    Thank you!
  5. #5
    Hardwire Newbie
    Join Date
    Aug 2006
    Posts
    50
    Do you mean "Peltier"? A thermoelectric module?
  6. #6
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Red face
    Quote Originally Posted by Hardwire
    Yes I meant "Peltier" thermoelectric cooling pad... I apologies for my miss typing...
  7. #7
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Can someone please make a recomendation for a particular switching current regulator that I can use to limit the current to 3 A...
    Thank you !
  8. #8
    Hardwire Newbie
    Join Date
    Aug 2006
    Posts
    50
    Quote Originally Posted by Frosty_47
    Thanks!
    Is it rated for 12V? I mean, is it 150W at 12V or is it always 150W no matter what the voltage range? Probably not, but I'm not too familiar with the details of these modules. Are you having trouble because you are cooling the processor down TOO much and getting condensation or something? Is that why you want to limit the current and not cool as much?
    Off the top of my head, I can't think of any better/simpler way than just using the resistor. 9W isn't too bad. Just get a 3hm: 25W power resistor and don't worry about wasting the current. Try to mount the resistor on metal so it sinks some heat. 9W might get a little hot.
    How about buying a less powerful Peltier module that will do what you want with 12V?
  9. #9
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,171
    Thank you !
    This circuit will do what you want.
    Origional PDF
    if I know the answer.
  10. #10
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Default Thanks
    Thank you for your suggestions!
    I don't understand one part of the circuit that Hero999 provided. Where am I going to get +15V for pin 8 and -15V for pin 4 of the TL082?
    Oh, and in order to limit the current to 3A, all I will have to do is change the value of R6? But to what value? Please explain.
    Thank you very much!
  11. #11
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,171
    It doesn't need to be +15V and -15V, it could be +12V and -12V which is supplied by a typical computer power supply.
  12. #12
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Smile Oohhhhh
    Quote Originally Posted by Hero999
    The -12V on my PSU is limitted to 0.5A, will that be sufficient ? Oh, and what value should R6 be in order to limit the current to 3A ?
    Thank you Hero999!
  13. #13
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,171
    Off course the -12V 0.5A supply will be fine. All the current comes from the +12V rail, the -12V is only used by the op-amp which doesn't take much.
    The article I posted shows you how to calculate the resistor values.
  14. #14
    things Good things Good
    Join Date
    Jan 2007
    Location
    Cairns, Australia
    Posts
    742
    peltiers aren't very efficient, so running them at under the power they require will be very unneficient. please also remember, peltiers don't generate cold, they only move heat to the other side, so basically the lower the power you give them, the lower the heat moving capacity is.
    The 3 laws of science....
    1. If it smells bad, It's chemistry.
    2. If it's mushy, It's biology.
    3. If it doesn't work, It's physics.
    www.laserchat.org IRC chat for laser and electronic related stuff.
  15. #15
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    400
    Unhappy
    I read the article over and over and can't seem to find (or perhaps understand) how to calculate the value of R6. Please help me out. I would greatly appreciate it.
    Thanks!
+ Reply to Thread
Page 1 of 3
1 2 3 Last
  1. Stabilised Power Supply with Current Limiting
    By mechie in forum Electronic Projects
    Latest: 11th May 2009, 10:20 PM
  2. Current Limiting Mosfet
    By nav2u in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th January 2009, 07:21 AM
  3. Need advice about this AC Line Current Detector
    By Avocado in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st March 2008, 05:37 PM
  4. Voltage
    By ElectroMaster in forum Electronic Theory
    Latest: 8th August 2007, 05:35 PM
  5. Current and Conductivity
    Latest: 2nd February 2007, 12:50 PM
Tags for this Thread
