| Ok, i just designed a board i want to make. How do i get it so i can just print it? At the moment, i got the layout done, but how to i get it so it looks like this; ![]() for the top and bottom?
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| De-select all except the layer you want to print. Select 'print' from the file menu. Select 'black' and 'solid'. Mirror if appropriate. OK. Check scale and adjust. | |
The bottom needs the layers bottom, pads, vias. The top needs the layers top, pads, vias. Your choice if you want to include the dimension lines around the board. If you use the dimension layer make the lines .01 or larger. Use change width. You mirror the top layer when printing it but not the bottom. And always black and solid. Be sure your printer is set to max darkness/print density.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| if you want to print that border, please move it further out, as right now it's intersecting the pads on the edges of your board. also with your board viewer open type this: run drill-aid <press enter> a window will pop up, enter some small number, like 0.6 (i think their suggestion of 0.3 is a bit small), hit OK this will fill in your donuts, making them easier to drill, and compensating for the fact you might have the exact size bit that the hole requires
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| Oh, i just found that pic on google. That isn't my board. This is the board i designed; ![]() edit: oops, wrong image...
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. Last edited by Marks256; 16th July 2007 at 10:58 PM. | |
| Now i don't know what to do next. I want to print it so i can do a toner transfer.
| Which part do you need help with? Go to View menu. Click 'Display/hide layers'. A box will appear. Check 'none'. Then check layers 1, 17, and 18. OK Select 'print' from the file menu. Select 'black', 'solid', and 'mirror'. OK. Repeat using layers 16, 17, and 18, and uncheck 'mirror'. | |
| A few hints on your layout: Your traces are narrower than necessary. They can probably be 0.02. change width .02 wherever it doesn't make them too close. Your vias are smaller than necessary. change diameter .04 | |
| More: Your connectors will be extremely difficult to solder on "top". If you're using the auto router then block the front of the connectors on top. (Layer 39, tkeepout). It should force all of the connections to the bottom. Or you could make layer 1 very expensive. | |
| Ok, i have no idea how to use eagle. My question was answered, but i have no idea how to use eagle, so i dont think i will make the board... I just kept all the defaults, and i have no idea what vias mean...
| Isn't via the connector from one layer to another?
__________________ Superman returns.. | |
| The vias are those green circles that would pass the signal from the red layer (1, top) to the blue layer (16, or bottom). | |
| via is a little hole, that would be filled with a special metal epoxy at a fabrication house. for DIY, vias are different, they're a much larger hole, that you have to carefully line up, and then solder a piece of wire through eagle is not the easiest to learn, but it is great software. your design isn't that complex, I recommend you rip-up all the traces the auto router laid for you and do them by hand. try to get as many of them using the blue layer 16 (bottom layer). only use the top layer where nessecary. set your width to 0.02 or 0.024 (24 mil is a standard width in eagle). toner transfer can do 6 to 8 mil but it gets kinda iffy - bigger is better when you're starting out. if you do need to lay a via, set the diameter to 0.06 or 0.07 and your drill to 0.035. soldering anything except big 'ol ICs and some other random components on the top layer is pretty difficult. it's better to assume you won't be able to solder it, so that means you can't connect to it with the top (red) layer. this will make sense to you if you lay your parts out on a simple print out of your design - many parts cover their pins... with a fabricated board, the special through-plating carries your solder to the top, with a diy board, that won't happen.
| Ok, i will try to figure out how to do that. If any of you would like, i will post the .sch file. I tried to google around for this, but i cannot find any good tutorials that show start to finish. I did find a few good ones to show how to make the schematics, but no good ones for the making of the PCB printout.
| On the lower left side of your design, you have a spot where a red trace merges with another at an acute 45 deg angle. This can form an "acid trap" and undercut the trace. Instead, always make your traces merge at at least 90 deg.
| How to properly do PCB edge connections in Eagle? | toodles | Electronic Projects Design/Ideas/Reviews | 2 | 10th April 2007 11:36 PM |
| Double sided PCBs in Eagle | Electronics4you | General Electronics Chat | 6 | 17th December 2006 04:06 AM |
| Eagle import/export -> Protel SE | midnitrcr | Electronic Projects Design/Ideas/Reviews | 0 | 10th November 2006 09:54 PM |
| Printing off of Eagle | lemonyx | General Electronics Chat | 8 | 1st June 2006 09:28 PM |
| smd's in Eagle | justDIY | Electronic Projects Design/Ideas/Reviews | 1 | 31st July 2005 09:22 PM |
