Old 17th July 2007, 02:59 AM   (permalink)
Oh, i see. I will fix that before i TRY to make the board...
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 17th July 2007, 03:49 AM   (permalink)
Hi Guys!
Is that Eagle Software good for layout? I haven't tried yet.
Is it free?
Can you give me a link to download
Thanks.
Suraj143 is offline
Old 17th July 2007, 06:12 AM   (permalink)
The light version is free.
http://www.cadsoft.de/cgi-bin/downlo...le/program/4.1
Marks256 is offline
Old 17th July 2007, 06:36 AM   (permalink)
Hi I downloaded EAGLE Lite edition & did a test run.
I draw a PCB Layout but it’s not showing the actual size. When I click the ZOOM IN or OUT its zooming to its own values. BEST FIT also showing very big.
How can I determine the actual size?
Suraj143 is offline
Old 17th July 2007, 07:19 AM   (permalink)
In the board editor under menu view there is a function called mark. This allows you to set a reference point. Set it at the bottom left of your board and the dimensions shown in the top left corner (starting with R) are now relative to the corner of your board.
Pommie is offline
Old 17th July 2007, 08:22 AM   (permalink)
Thanks mike I'll give a try with your idea.
Suraj143 is offline
Old 18th July 2007, 05:24 AM   (permalink)
I have been using a one person commercial license that came with the autorouter, but after my second PCB, I have stopped using the autorouter. There is only so much it can do, and it usually does more wiring than necessary, at least for my designs.
One helpful hint: After placing all you components, hit the "ratsheet" button that looks like an x. That will reorganize the yellow air wires to get them as short as possible. This is useful when you have several connections to the same component pin. Otherwise, when you use autorouter, it will make unnecessary long traces and extra ones too.
I am still a noob at it, and that one tool helped a lot.
Ambient is offline
How to properly do PCB edge connections in Eagle? toodles Electronic Projects Design/Ideas/Reviews 2 10th April 2007 11:36 PM
Double sided PCBs in Eagle Electronics4you General Electronics Chat 6 17th December 2006 04:06 AM
Eagle import/export -> Protel SE midnitrcr Electronic Projects Design/Ideas/Reviews 0 10th November 2006 09:54 PM
Printing off of Eagle lemonyx General Electronics Chat 8 1st June 2006 09:28 PM
smd's in Eagle justDIY Electronic Projects Design/Ideas/Reviews 1 31st July 2005 09:22 PM
