I have been digging about and I'm trying to build a Computer controlled (via serial port) switch to cold boot my router should it fail to respond to ping. Im no guru at all, I can solder with no problems but I want to make sure this is safe so need expert help It is a windows Server 2003 computer (consider it XP if you like) unless someone has already done this I will sort out the programming / ping monitor stuff when this switch actually works. can be supplyed from the ATX molex if you like. Simple as possible would be nice. The switch must remain ON / closed if the power fails to the monitor thing, ie if its fed from the ATX supply and the server goes down, dont want the router following it. Thanks in advance for any help you may provide! |
How about this.
Use a RS232 flow control signal that you can toggle on the PC. Maybe RTS.The following circuit is more complex but it shows what transistor and discretes are needed to drive a relay from RS232. A Hardware watchdog and shutdown button
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
Hi, thanks for your reply. That link never seems to load...
Does it work for you?? |
| computer controlled power switch | Michael Daly | Electronic Projects Design/Ideas/Reviews | 2 | 25th June 2007 06:14 PM |
| Computer Controlled Radio-Controlled Car help | Suds | Electronic Projects Design/Ideas/Reviews | 6 | 29th March 2007 09:23 AM |
| RC car controlled via computer | drage | Electronic Projects Design/Ideas/Reviews | 6 | 22nd October 2006 11:37 AM |
| Computer Controlled Controller :P | illitirate.is.me | Electronic Projects Design/Ideas/Reviews | 1 | 28th July 2006 02:38 PM |
| Computer controlled relays | numptyboy | General Electronics Chat | 2 | 3rd April 2005 10:48 PM |
