Old 16th July 2007, 05:03 PM   (permalink)
Question Joystick / DC motor control Question
I am building a dual motor controller using either two HIP4082 h-bridge drivers or four IR2110 high & low side drivers. I'm planning on using IRFP064N Power MOSFETs. This controller will be drivin by a joystick and will use mixed steering(tank/skid steering). This will be for a powered cart that use Wheelcair motors.
My question is:
Is there a hardware only way to control the drivers with a joystick. or will I need to use a pic. I just got a Mikroelectronica EasyPIC4 and am learning about pic microcontrollers but I'm not to good at programming yet. any schematics or links that could help would be great.
HYTECH is offline
Old 16th July 2007, 05:32 PM   (permalink)
A real joystick with serial connections needs PIC. A bare bones joystick that is more like a stick that pushes 4 buttons can be done directly (but no proportional control).
dknguyen is offline
Old 16th July 2007, 07:12 PM   (permalink)
I will be using a joystick that has 2 pots for x/y axis 2.5v centered 0-5 volts proportional
HYTECH is offline
Old 16th July 2007, 07:49 PM   (permalink)
http://www.dprg.org/tutorials/2005-11a/index.html
There may be some modifications depending on how your H-bridge works (one PWM input where 50% is stop, two PWM inputs, or four PWM inputs for independent control of all transistors). You'll need at least two of these circuits for each axis (obviously). THis is easy to do with if you have two joysticks, one for the direction of each motor. Just hook them up separately.
If you are using one north-east-west-south joystick, you will need to mix the signals somehow so it'd be easier just to use a PIC.
dknguyen is offline
Capacitor Charge/Discharge question ThermalRunaway General Electronics Chat 25 12th August 2008 05:48 PM
**need help with AC to DC and DC to DC power supply TT** ahdehling Electronic Projects Design/Ideas/Reviews 5 25th June 2007 09:40 PM
DC power plant design question Dialtone General Electronics Chat 6 1st June 2007 11:06 PM
24 to 12 volt Dc to Dc converter windozeuser General Electronics Chat 4 30th January 2007 03:15 AM
Joystick port and sensors haydxn Electronic Projects Design/Ideas/Reviews 5 26th November 2004 02:40 PM
