| What are some good oscilloscopes? I am thinking of buing one (ebay, of course). I don't think i will need anything over 100mhz. More is better, though.
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| Ok, i guess 100MHz is quite a bit...
| I really like the Fluke 199C we have at work. Portability is nice. The small Tektronix are ok too, but I always find myself using the Fluke more often. | |
| Umm... maybe i should have mentioned my price range is a maximum of $150...
| I just got a Tektronix 2212 off ebay. Its only has a 60mhz bandwidth, but for me, right now, its fine. I can't remember now what I paid, but it was around 150, with 3 probes and manual. About a month after I bought it, my dad came into a 100mhz HP scope for free What I would like to know, and maybe some of you can tell me, is what is the advantage of 100mhz over 60mhz or even 15mhz. What falls in that 60-100mhz range that is commonly measured? 100mhz is mighty fast, and to me is only usful in RF or computer processors. and 100mhz dosn't cover much RF past HF ham bands. And your not even talking 1 mhz there. | |
| | (permalink) | ||
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 12th July 2007 at 04:39 AM. | |||
| If you are doing anything digital with a PIC at frequencies like 20MHz then you will want 100MHz or more. A square wave has as its component frequencies at X (the base frequency), then at 3X, 5X, 7X, etc (the harmonics). It takes several of the harmonics for it to look like a decent square wave. So you'll want 100MHz minimum for say a 20MHz signal. | |
While a 100MHz+ scope would be nice, it's hardly essential, and is only needed in an incredibly small amount of cases - probably 0.1% or less?, for normal hobby use. A 20MHz scope will do almost everything you ever need, and a 20MHz double beam scope would be FAR, FAR more useful than a 100MHz single beam (assuming you could find a 100MHz single beam?). But ANY scope is a lot better than no scope, don't get carried away chasing high performance you might never need. | ||
| *shrug* I'm frequently doing things that require the bandwidth. 200ns nstruction cycles ar 5Mhz base frequency, so I'd want at least 25MHz scope, and I might be looking for things beyond that at times (looking at transition times of switching devices, for example). Or looking at the HF noise spectrum of switchers, or trying to find out why and where in the heck some circuit is oscillating. At my old job they had real scopes - 8GHz Agilent's IIRC. What I'd really like is an MSO with bus decoding ability. We had a tektronix dealer here a few weeks ago demo one and it was awesome. Just my opinion though. I admit I am an equipment snob with a tendency towards overkill. And nah, the crystal output is a sinewave with some small harmonics on top. I got curious one day and measured it. | |
| Ok. I am really not sure what i need in a scope, so i am not sure what information to give. I am just going to use it on small digital circuits. Just looking at some waveforms. learn a bit about o-scopes. So what would be the best bandwidth to get? 25MHz? EDIT: What does "double beam" or "dual Channel" mean? Does it mean that it can monitor 2 frequencys at a time? So, instead of just being one line on the display, there could be up to 2?
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. Last edited by Marks256; 12th July 2007 at 06:37 PM. | |
Do not overlook the HP/Agilent scopes. They are less sought after then tech scopes but rock solid just the same. Get as fast or as slow a scope as you can afford. But as Nigel said be sure to get a 2 channel unit.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| Yep, i see the importance of a 2 channel scope. I am surfin' ebay right now. EDIT: What is a Digitizing Oscilloscope?
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. Last edited by Marks256; 12th July 2007 at 07:44 PM. | |
| Presumably it's a digital scope - this converts the signal with an ADC, and stores it in memory, so you can freeze and store one shot events. As for the type of scope you need, consider it as you would a car!. Speakerguy79's point is that you MUST have at least a Porsche 911 Turbo, because you can't do 170 miles per hour otherwise. My point is you spend more time going to the shops, or sat in traffic, than on the race track! | |
| What kind of o-scope do you have, Nigel? If you don't mind me asking.
| A basic dual channel 200MHz digital scope is a Z28 Camaro at best, you can get those for 1-1.5k from a number of companies. I'm just one of those buy it once, buy it for life types. That Tek MSO4000 I saw a few weeks ago starts qualifying as supercar territory. The memory storage and bus decoding was just awesome. It would make debugging I2C systems a joke. Also, definitely get two channels. That is certainly more important than speed. | |
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 02:45 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Digital and analog oscilloscope | patroclus | General Electronics Chat | 34 | 12th July 2006 03:34 AM |
| Oscilloscope DL1620/DL1640/DL1640L | tkvenki | General Electronics Chat | 0 | 10th January 2006 01:37 PM |
| anyone know anything about digital oscilloscope design? | sanjeevan_a | Electronic Projects Design/Ideas/Reviews | 11 | 2nd August 2003 06:58 AM |
