Old 11th July 2007, 05:18 PM   (permalink)
Question 12Volt DC Transformer
Hi there to you all, Just have a query regarding the above transformer,I'm thinking of setting up a car Stereo in my sons bedroom, and in the stereo theres a 15amp blade fuse, does this mean that in order to run this stereo from the mains I have to use a 12 volt dc 15 amp transformer? Also I havnt been able to source one from anywhere! Does anyone know where one of these can be obtained from if this is the case? Many thanks
arnonick is offline
Old 11th July 2007, 06:03 PM   (permalink)
A transformer supplies alternating current 'ac', you require a 12V 'dc' direct current power supply. The 15amp fuse is not an indication of the current requirement of the radio, I would expect it to be about 5 to 10 amps 'dc'.
The way to check the radio, would be to connect it to a 12v car battery [also the speakers attached to the radio] and measure the current into the radio using a ammeter.
Does this help?
ericgibbs is online now
Old 11th July 2007, 06:30 PM   (permalink)
A 12V car battery is 13.8V, not 12V.
audioguru is offline
Old 11th July 2007, 06:33 PM   (permalink)
Cheers for that i will check it out
arnonick is offline
Old 11th July 2007, 06:40 PM   (permalink)
You need a mains 13.8V power supply.
Maplin sells them up to 10A, if it's enought for you.
http://www.maplin.co.uk/module.aspx?...o=231&doy=11m7
If you want 15A then I'm sure other places like RS Components and Farnell but you have to place and order, you can't just turn up and buy it.
Screen name: Aloone_Jonez
Hero999 is offline
Old 11th July 2007, 06:44 PM   (permalink)
Its 13.8V when its fully charged, it quickly falls to 12V,, its rated at 2V/cell * 6 = 12V
I suggest you look at this link.
http://en.wikipedia.org/wiki/Lead-acid_battery
Old 11th July 2007, 07:27 PM   (permalink)
13.8V when charged in standby mode, and they always charged in standby mode. Your stereo is both safe when supplied with 12V or 13.8V DC.
Blatman Bond is offline
Old 11th July 2007, 07:45 PM   (permalink)
Most car radios are rated with a 14.4V power supply.
Most people listen to their car radio with the engine running and charging the battery at 13.8V.
Old 12th July 2007, 07:54 AM   (permalink)
No one's disputing this statement.
Many people also listen to their car radios with the engine switched off, that one of the reasons
your ingition key has those intermediate positions so the auxiliary devices can be operated.
As 'blatman' says the radio is designed to work safely with a 12V or 13.8V supply.
As 'hero' suggests I would also buy a 13.8V psu.
BUT a lead acid cell is still a nominally rated at 2V/cell, which gives a nominal voltage of 12V for a lead acid car battery,
not 13.8V which you suggested.
Old 12th July 2007, 03:58 PM   (permalink)
The spec says that the stereo allowance is 11v-14v.Cheers for the advice fellas
arnonick is offline
Old 12th July 2007, 05:52 PM   (permalink)
Then its output power per channel at clipping (low distortion) into 4 ohms is about 17W RMS with a 14V supply and only 9.4W with 11V for its supply.
Old 12th July 2007, 10:23 PM   (permalink)
How many channels?
If it's 8hm: per channel, each channel takes 3.5A so four channels would require 14A plus any biasing current what's required for the microcontroller and any illumination.
But that's only the peak requirement at full volume, I don't know what peak current of the 10A Craplin power supply is but it'll be fin providing you don't play it too loud.
Hero999 is offline
Transformer Problems? MsStateDawg Electronic Projects Design/Ideas/Reviews 15 2nd November 2007 11:17 PM
**need help with AC to DC and DC to DC power supply TT** ahdehling Electronic Projects Design/Ideas/Reviews 5 25th June 2007 09:40 PM
24 to 12 volt Dc to Dc converter windozeuser General Electronics Chat 4 30th January 2007 03:15 AM
Problems selecting a PCB Transformer NewcastleSAR Datasheet/Parts Requests 31 4th January 2007 08:16 PM
Differential transformer how to measure this signal sardineta Electronic Projects Design/Ideas/Reviews 18 7th October 2004 03:31 PM
