Hello,
Im trying to build a functional circuit for mixing 2 audio signals with a single supply opamp @ 3.7V. Ive gotten a simple working circuit for dual supply, but am not able to get a single supply circuit working? I only get popping sound at the output of the opamp. dual supply testing -I have tested the mixing circuit with a dual supply lm348 +-5V unity gain no problems. single supply testing -I have purchased a single supply opamp TLC084 and tested it with a wave generator up to 20khz no problems @ 200mvpp and unity gain no problems -When i use the same circuit and instead of inputing the wave i input the audio signal ~200mvpp. The audio is only amplified in for very small periods and sounds noisy and poppy from the speaker. questions 1 - I do not know why the audio is signal is not continuosly being amplified as the wave generator worked great through 20 khz?? 2 - Is there some incompatibilty with this single supply opamp tlc084 that i am using, would there be a better option for my application? Thanks for the help, trying to get a fix on all this fun analog stuff |
Experienced Member
You forgot to attach your schematic.
The minimum supply voltage for a TLC084 is 4.5V. Yours is only 3.7V. Its inputs must be biased properly at about half the supply voltage when it has a single supply.
Uncle $crooge |
(permalink) | ||
Thanks for the reply Audio.
Attached is a simplistic setup of the opamp with only one input. Quote:
Thanks |
Experienced Member
Opamps don't work if their inputs are at the negative supply voltage which is ground in your circuit. The inputs must be biased at about half the supply voltage like this:
Uncle $crooge |
Thanks for the help! I think im going back to the books on opamps as there is so much i dont know and cant remember!
In case anyone is interested i found another great resource for single supply op amp design by TI. |
Experienced Member
I don't believe it. Texas Instruments show a single supply non-inverting opamp without any input bias voltage.
Uncle $crooge |
Super Moderator
Experienced Member
The value of the biasing resistor should also be equivalent to R1 and R2 in parallel.
| Audio Mixer using transistor | electronic mind | General Electronics Chat | 13 | 24th February 2005 10:08 PM |
| Mobile audio mixer, w/ high level inputs | Earthshaker | Electronic Projects Design/Ideas/Reviews | 7 | 13th December 2003 08:33 AM |
| Power Supply Design & Zeners | Noggin | General Electronics Chat | 2 | 6th October 2003 02:38 PM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 01:10 AM |
