+ Reply to Thread
Results 1 to 11 of 11
Thread: Buffer
  1. #1
    hykwei Newbie
    Join Date
    May 2007
    Posts
    27
    Default Buffer
    Hi Guys!
    I need to construct a high speed buffer (for a 20 MHz signal)...and I don't know whether a 'NPN Common Collector Amplifier' will be suitable for this kind of situation. (The circuit that described in http://hyperphysics.phy-astr.gsu.edu...nic/npncc.html)
    or maybe a high speed amplifier will be an easier choice? somthing like OPA633 op-amp?
    Thank you for your helps!
  2. #2
    Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,664
    Blog Entries
    1
    What are you going to switch?
    Not all General Purpose Transistors suits for your job.It needs High Speed Switching transistors.Also the circuit is a common collector type.
    Give us more details what you want to switch?
  3. #3
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,852
    Blog Entries
    13
    Quote Originally Posted by hykwei
    Hi Guys!
    Do you want a HS buffer or HS amplifier [with inversion] ?
    Whats the waveform shape and amplitude?
    Is it a referenced to zero +/-Vsignal?
  4. #4
    hykwei Newbie
    Join Date
    May 2007
    Posts
    27
    Hi Guys
    I want to build a High Speed Buffer...
    I am basically building a data capture system, the receiving signal coming out from the sensor is a fixed frequency, 20MHz sinusoidal signal...amplitude varies from 20mV to 1V approximately...so I want to put a high input impedance buffer straight after the sensor stage so the signal will not be loaded or affected by the rest of the electronic circuits...
    I am now thinking of PN918 transistor...but just want to know will there be some better options?
    Thanks!
  5. #5
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,724
    What is the source impedance (resistive and reactive) of your sensor? What is the impedance of the load (resistive and reactive) you want to drive? Are there any cables involved in getting the signal from the sensor to the load? The answers to all these questions are important when selecting a buffer.
    Also, since the signal is a single frequency, I'm assuming you can AC couple it to the load. Is this true? if so, then the DC offset of the buffer (common collector stage) will not be an issue.
    Ron
  6. #6
    hykwei Newbie
    Join Date
    May 2007
    Posts
    27
    I havn't actually measured the source impedance, but it should be fairly low...as it is simply a coil which can detect the magnetic induction signal (mutual inductance experiment...) The electronic circuits is going to have some distance away from the sensors, so it's going to be some cabling effect if I connect my sensor directly to the data acquisition system (using a co-axial cable). therefore I think putting a buffer in between the sensor and my data acqusition board is necessary....If I remember correctly the input impedance of the co-axial cable is 50 ohms)
  7. #7
    Optikon Newbie
    Join Date
    Sep 2003
    Location
    Cleveland, OH, U.S.A.
    Posts
    1,729
    Hi Guys
    Thanks!
    Better options are high speed opamps like you mentioned. If it were me, I wouldnt go through the trouble of a multi-stage transistor amplifier design when opamp solutions are available.
  8. #8
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,724
    Emitter followers (common collector) tend to oscillate with inductive sources and/or capacitive loads. You would be better off with a high-speed op amp, as Optikon says.
    Ron
  9. #9
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,852
    Blog Entries
    13
    Have a look at this HS opa.
  10. #10
    Bob Scott Excellent Bob Scott Excellent Bob Scott Excellent Bob Scott Excellent Bob Scott Excellent Bob Scott Excellent
    Join Date
    Apr 2006
    Location
    Vancouver, BC
    Posts
    344
    I think it might be the appropriate time for me to share my thoughts about using Analog Devices parts. Just pause and have second thoughts:
    1. Does this part have a second source or alternative replacement?
    2. Beware that when you finalize the schematic and before you send the schematic out for layout, that the pin numbers match the specified package. I know of more than one engineer with prototype boards where the multipin AD devices are hanging off the board on kynar wire legs.
    Bob
  11. #11
    RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent
    Join Date
    Oct 2005
    Location
    BC, Canada
    Posts
    1,448
    Blog Entries
    1
    Quote Originally Posted by Bob Scott
    Bob
    Hey Bob, we are fellow Vancouverites! Obviously you are a working engineer cause most of the guys on these boards dont "send the schematic out for layout" as they are usually one-man shows. I left the big company life not long ago and was happy to get back to doing my own pcb layouts for a change. Takes me back to my youth. Anyway, your post reminded me of the distaste our buyers had for Maxim parts. The parts were often unique to Maxim and the buyers had "difficulties" negotiating anything with them. So we were told to avoid. I haven't had logistic problems with AD parts, myself.
    RadioRon
+ Reply to Thread
  1. buffer for the pic
    By Gaston in forum Micro Controllers
    Latest: 1st February 2007, 10:29 PM
  2. Need some help with a code provided by ATMEL
    By ikalogic in forum Micro Controllers
    Latest: 23rd January 2007, 02:46 PM
  3. Interfacing RS232 buffer with MSComm
    By wingbar in forum General Electronics Chat
    Latest: 11th March 2004, 05:30 AM
  4. Op-Amp buffer problem
    By Scruit in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th February 2004, 04:34 PM
  5. Anybody got a buffer circuit schematic
    By Nostrafus in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th July 2003, 03:27 PM
Tags for this Thread
