Old 6th July 2007, 03:39 AM   (permalink)
Question soldering irons what kind is best?
Butane, Electric or Cold Heat?!
I think I know that cold heat is only good for a few situations but I heard that your "Radio Shack" style plug in 15w, 30w soldering irons are also bad at times because they have an electric charge that can damage IC's etc?
IS this true and then should I use butane irons etc for this job and are they any good and does anyone have any suggestions on make and manufacture of these types of guns?
Thank you greatly
Sincerely,
Kevin in Alaska
Cheers!
The circumstances of one's birth are irrelevant. It's what you do with the gift of life that determines who you are.
KevinAlaska is offline
Old 6th July 2007, 04:07 AM   (permalink)
ha, yes i think the electric ones do have a charge. i was soldering an led, with me holding one of the leds legs, and soldering the other, and it lit up!!!!
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is online now
Old 6th July 2007, 04:37 AM   (permalink)
A good quality electric iron is the best choice. They allow you to choose different tip sizes for more or less heat transfer, to set the tip temperature, and they have grounded tips for ESD protection. An example is the Weller WES51 or the Hakko 936-12.
RadioRon
RadioRon is offline
Old 6th July 2007, 04:45 AM   (permalink)
Thank you greatly
Sincerely,
Kevin in Alaska
Cheers!
I just use a typical Solding Iron. 110 Volt, 30 watt type.
In all my life I have NEVER had any Problems.
Even the 30 watt Radio Shack ones are OK.
I keep one in my truck to use from my power inverter when needed.
Cold Soldering Irons are NOT Suitable for Electronics.
And Butane ones are Expensive to operate. But Good when you don't have Power available.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 6th July 2007, 05:31 PM   (permalink)
You can get ESD safe soldering irons.. go search for them, they're out there - no problem there. Don't use the cold-heat methods, they don't work well.
Optikon is offline
Old 6th July 2007, 06:28 PM   (permalink)
I find the 40W radio shack irons perfectly fine for large work, IF you keep the tips tinned. They are not so good for fine work. I usually use it for soldering up speaker crossovers (12-18gauge type stuff). Tip variety is poor.
For electronics work, I would get something like a Weller iron with replaceable tips that is self-regulating to something like 700 degrees. I think the are $50.
I am REALLY trying to find a Hakko FX-951 stateside; although I'm glad I haven't since I would be tempted to buy it. Maybe I could talk work into getting one so I could try before I buy Our stations are old as can be anyway.
speakerguy79 is offline
Old 6th July 2007, 09:06 PM   (permalink)
All soldering irons I've seen that run directly from the mains have earthed tips, it's a legal requirement!
Screen name: Aloone_Jonez
Hero999 is offline
Old 6th July 2007, 09:17 PM   (permalink)
It certainly wasn't a legal requirement, but perhaps things have changed? - and certainly some high end irons, intended for CMOS working, couldn't be earthed to prevent static problems.
Old 6th July 2007, 09:27 PM   (permalink)
I suppose if it's double insulated then the tip doesn't have to be earthed but I've never seen a double insulated iron before.
Hero999 is offline
Old 6th July 2007, 11:37 PM   (permalink)
From a while back.
An inexpensive yet quality soldering station
It is a temperature controlled station for under $50US. Also sold in the UK under other brand names.
3v0 is online now
Old 6th July 2007, 11:59 PM   (permalink)
that's strange, why did the led light up? (in my first post in this thread) it didn't light very brightly, but it certainly did? why?????
Old 7th July 2007, 01:12 AM   (permalink)
Doesn't make Sense unless you had a Grounded Tip and the Other side of the LED was connected to Something Supplying Power to it.
chemelec is offline
Old 7th July 2007, 07:52 AM   (permalink)
Antex used to make special ceramic elemented ones for CMOS use.
Old 7th July 2007, 10:43 AM   (permalink)
I have seen that happen too with the high efficiency LED's.
These seem to glow up a little, especially when a soldering gun is used, which has a double insulated 230 / 3 Volts transformer.
Probably something to do with leakage or possible capacitance between the soldering iron and the LED being soldered.
It however doesn't damage the LED.
I use for electronic projects a Dick Smith Electronics T 2000 soldering iron which has variable temp. control and 230 / 24 volts heater with exchangeable tips.
The tip is earhed and so is safe to use for CMOS IC's.
RODALCO is offline
Old 7th July 2007, 01:34 PM   (permalink)
I've made a white LED light by holding one end and touching the other end on a radiator.
I was acting as an aerial picking up electrical noise, the LED was acting as a rectifier and glowing and the ratiator was acting as an earth.
I suspect that exactly the same thing is happening here.
Hero999 is offline
Basic Soldering & Desoldering Guide ElectroMaster Electronic Theory 15 13th November 2008 01:23 PM
Soldering Irons Ads General Electronics Chat 9 15th November 2006 12:13 AM
Solder and Soldering Irons digital General Electronics Chat 7 19th August 2005 01:37 AM
Soldering Irons Clyd3 General Electronics Chat 8 3rd August 2005 09:20 AM
Soldering Station Confusion TekNoir General Electronics Chat 16 1st May 2005 05:49 AM
