*What’s the meaning of LINEAR devices? Why they call like that?
*What is the meaning of switch mode power supply? What’s the difference between normal power supply and a switch mode power supply? Thanks |
Superman returns..
y = mx + b where m is the slope of the line and b is the y-intercept |
Switching power supplies work in a similar manner to the Phased Locked Loop oscillator in that the actual output is compared with what the output SHOULD be, which generates a reference value known as the Error Voltage. This is feed back into part of the input to correct the problem, until there is no error voltage coming from the comparison circuit. This is why switching power supplies don't vary their voltage and PLL synthesized tuners don't frequency drift.
The difference is that switching power supplies use a switching stage on the output rather than a transistor that never saturates.
Basically linear regulators have a class A output stage and switching regulators have a class D output stage.
Actually, the true definition of 'linear' in linear systems is this:
f(x) + f(y) = f(x+y) Which is quite interesting, because contrary to the completely natural seeming assumption that a line equation would obviously be a linear function, y = mx + b is surprisingly not a linear equation, unless b = 0. Technically, a linear system cannot have a DC offset. This is, of course, if I remember my linear systems and signals course from college oh so many years ago. I only remember this because of a question essentially based on this on a test that killed 90+ % off the class. |
http://en.wikipedia.org/wiki/Linear_system The definition does not preclude "offsets." which, makes sense. We all know y=mx + b is linear even for non-zero b. |
Sorry, top ten engineering school in the country. Maybe you guys should go through the math before telling someone they're wrong. Example:
f(x) = 2x + 5 f(2) + f(4) = 9 + 13 = 21 f(2+4) = 17 f(2) + f(4) != f(2+4) Since f(x) + f(y) must equal f(x+y) for a system to be a linear system, f(x) is not linear (as far as linear system theory goes; it's still a straight line on graph paper though). This is straight out of the B.P. Lathi textbook that most colleges use. Last edited by speakerguy79; 6th July 2007 at 02:45 AM. |
Have it your way, it's an advanced treatment.
Your basic definition apllies to linear maps from one vector space to another. In this case adding the constant makes it an affine map. This is way beyond the original poster's question and our answers were given in the context of elementary algebra. I'm pretty sure the OP did not have this higher treatment in mind when he asked his original question. Last edited by Papabravo; 6th July 2007 at 06:35 AM. |
Smart arse.
As far as I'm concerned linear = analogue = an infinite number of quantities and switching = digital = two possible states (on and off).
You need x1(t) & x2(t) inputs and compute y1(t) & y2(t) outputs from a system under examination. The system under examination is linear if for scalars a & b, a*y1(t) + b*y2(t) = H{a*x1(t) + b*x2(t)} if we use x1(t) = 2*t+5 and x2(t) = 3*t+1 and choose the system to be say differentiation d/dt then try it. I worked it out and it shows that the *SYSTEM* is linear. And we all know the operator d/dt (differentiation) is linear. If the system is constant gain of 1 just maps input to output, that too meets definition of linearity. And the inputs have offsets to them. Your example is something else. but to test a system for linearity, you must try two functions on input. |
Yeah, I can be a smart ass for sure
But to answer the OP's post: Linear regulators take a noisy voltage in, step it down usually by 2V or more to your desired voltage, and filter out a lot of the noise. They are inefficient because they dissipate power in direct relationship to how much voltage drop you have across them, and the current through them. Ex. A regulator with 35V in and 5V out will dissipate a whopping 45W when supplying 1.5Amps.That's 45W dissipated as heat to 7.5W delivered as power The big plusses with linear regs are very very low ripple and noise, and good output accuract (1% easily acheivable). Also really really cheap. Good to use in analog cktry. Switchers - don't know much about how they are designed, but they are much more efficient than linear regulators with the drawback of high frequency noise introduced onto the power supply lines. Switchers actually increase in efficiency as output power goes up, maxing out at about 80% of their full output power (at anywhere from 75 to 95 percent efficiency). Switchers can be quite a bit more expensive. I only use switchers where efficiency is a concern or I need to generate multiple and/or positive and negative voltages from a single DC voltage source. Other than that I always use linears. Last edited by speakerguy79; 6th July 2007 at 01:51 PM. |
Any analog work I do, I avoid switchers like the plague because of the noise issues. Also note, it takes a pretty experienced designer to squeeze every last bit of efficiency out of a switchmode design. 80% is acheivable with your eyes closed in most cases. In my experience to get into the 90%'s requires much more work. The companies who sell switchmode controllers are making it easier on designers these days to acheive the higher efficiencies. |
| Need help testing AC/DC power supplies | wasman | Electronic Projects Design/Ideas/Reviews | 3 | 25th July 2003 03:56 AM |
| AMP ratings on power supplies | vanhin | General Electronics Chat | 2 | 28th June 2003 06:12 PM |
| RE:- help!! AC switch mode supply for low voltage lighting | mikegaylor | Electronic Projects Design/Ideas/Reviews | 1 | 19th April 2003 02:10 PM |
| Help with AC switch mode supply | mikegaylor | General Electronics Chat | 0 | 18th April 2003 06:12 PM |
| Switch mode power supply | Nonx | General Electronics Chat | 10 | 7th March 2003 04:18 PM |
