| Yeah, I know, kind of a stupid an irresponsable idea... It just wouldn't leave my head all morning at work. Guess it's kind of our July 4th holiday, freedom from british rule... Anyway, I've got maybe a dozen or so cans of partially used, paints, cleaners, and so forth, that have been sitting around for way too many years, and no particular plans that might include using any of them in the years to come. The contents may not even be useful. As a young child, I remembered seeing some older kids making some impressive jets of flame with a lighter, but I was never that comfortable with stuff that could explode. Just curious if an electric spark could ignite this stuff, or if an actual flame is needed... | |
| You'll have better luck with a flame - and I mean luck! Think about it: when you use flint to light a propane touch, there's a series of sparks, not just one, and there's a much steadier flow of fuel coming out than there will ever be in an aerosol can. You'd be very lucky to be able to start a flame with an aerosol can if, for instance, you tried to start it with a single spark, unless the nozzle of the spray can was very close to the spark. You'd have better luck with a tazer or something repetitive like that. The only time I've seen anyone keep a continuous flame on an aerosol can was when they were holding a lighter constantly in front of the nozzle. I think that's how flame-throwers work, too. They don't keep a continuous flame going by themselves like a propane torch - I guess it's got to do with how they spray the fuel. I've never been stupid enough to try any of this, by the way. It's exactly the kind of thing I enjoy observing and criticizing more than experiencing myself. So... video tape the whole thing, for my amusement. Last edited by Hank Fletcher; 29th June 2007 at 06:30 PM. | |
| I agree with Ron H. Search on hair spray cannon or potato cannon. Great fun with the kids, Independence Day, etc. I used a replacement flint starter from something...they were at the local hardware store. I thnk they were originally replacements for Coleman laterns. Results vary with the brand of hair spray. Seems the cheaper the better. I also believe it may be a little safer, because the amount of combustible is limited to the cannon barrel. Never had one explode or even crack. John | |
| Unless the right ratio of fuel and air exists you'll get nothing. An example: a propane storage tank has some level of liquid propane- the gas above it is gaseous propane - that is unless someone has added something. Without oxygen neither the liquid or gas will ignite if you were to insert a spark plug and run a continuous spark. If you had a chamber with a spark plug/ignition coil and you started with pure propane you could spark it all day at 100% propane and 0% air. Start to bleed in some air and the ratio changes - when it gets to the upper explosive limit (UEL) - kaboom! Run the test the other way with 0% propane and 100% air - add propane and it goes off when you hit the lower explosive limit (LEL). Now, you could get ignition if the spray can were pressurized with compressed air over a volatile combustible liquid but compressed air isn't often used for that.
__________________ stevez | |
| How well does paint flame up? I've never tried it myself. I know carb cleaner and either will make a flame, but i don't know about paint. I can't imagine all cleaners would flame either. Brake cleaner would, but scrubbing bubbles, prolly not? Anyone ever been crazy enough to try it? | |
| Haven't seen anybody do it in the last 30 or so years, so guessing it's only for a brave (stupid, drunk, or stoned) few. Judging from what I remember of the fumes, all these should be flameable (believe its mentioned on the cans). Not sure what changes to expect from age. I guee the best, would be a propane torch, and a soleniod or servo to depress the nozzle button on the can. Video is doubtful, I'll be some place where I'll hopefully feel safe from the potential of flying bits of metal. The backyard security camera is Black and White (could swap it out), but no way to transfer from VCR. Kind of thinking it might be best to replace the plastic nozzle with a small diameter metal tube, so it sprays straight up. Think it might make things a little safer, as everything could go into an old 55 gallon drum. If it does explode, should blow in a safer direction... | |
| I used to use a hair lacquer flame thrower on irritating insects. Hold one of those cheap disposable lighters set to large flame just underneath and in front off the aerosol nozzle. Probably best to do this outdoors Have fun ! PS cellulose paints (as found in car shops) are great! Last edited by CheapSlider; 29th June 2007 at 08:27 PM. Reason: corrcting of spelinn | |
I would recommend sticking to hair spray (propane propellant/lacquer base) or straight propane. Spray lacquer should also work -- you may even use it as hair spray -- but it will tend to gum up the cannon more. I have never used MAPP. It should be smoky from the acetylene. John | ||
| You may have to register to see this oxygen-propane cannon. | |
| It's low-tech, but a soda straw partly packed with flour makes a neat flash. Just blow it out over a candle flame. It's the same kind of phenomenon that blows up the occasional grain elevator. And there's no toxicity if you get some in your mouth. Fairly safe for kids. | |
| Bb Gun! Blows Up Good! | |
| well as for 4th of july freedom from british rule is bush any better ? god what the hell do americans think about when voting ? if you want to throw flames just bugger off to iraq
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | |
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | ||
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| min. distance in ultrasonic distance meter | Maryam | Micro Controllers | 2 | 9th August 2004 11:18 AM |
