I am just reading a chapter on safety around electricity. Is this following scenario correct? If i had a situation where i had a circuit powered by a large d.c. voltage supply from a battery. (Enough to cause a shock). I could strip the wire going from the negative side of the battery before it meets its first resistance and grasp the wire without any shock at all. Thanks Mark S. | |
I would not bet my life on that ..... What you are describing might be the ideal situation. In real life there can be breaks in the conductor or at connection points, etc, that cause things to depart from the ideal situation.
__________________ stevez | |
| | #3 | |
If there is leakage to ground of the positive side of the battery system you could get a serious electrical shock, never mess with high voltage DC. | ||
You can grasp any wire as long as you don't complete a circuit. Birds land on high tension wires with no problem and you could also if you could get there without touching ground.
| | #5 | |
In fact overhead cable repair men are lowered onto 'hot' high tension cables, using a helicopter. | ||
| | #6 | |
UK telephone exchanges* use positive earth. In which case it could be possible to get a shock by making contact with earth while holding the stripped negative wire. It also depends the type of load this wire is connected to:- suppose it was an inductive load and the battery end became o/c ? *Telephone Office - usually about 50V but can be 80V | ||
| | #7 |
When you start dealing with VERY high voltages things can get a bit weird. Electricity has mass and inertia. When it is moving under the impetus of extreme voltage it can (and will) ignore such things as insulators, Ohm's Law, and the fact there is no APPARENT path to ground. High voltage corona leakage can zip right past a suitable conductor to ground on its way to zap something 3 feet away that just happened to be in its path to ???.
| | #8 |
Until you gain experience and knowledge you should be very careful working on or around any voltage above say 60 volts. Even low voltage like 12 volt automotive circuits can burn you very very badly if you short out a circuit with say a finger ring or metal watch band. The problem is that current and voltage are 'invisible' and there is no substitute for proper lock out tag out procedures and careful measurement before physically touching conductors. Lefty | |
| | #9 |
Shorting a watch band across a car battery would be extremely nasty.
| | #10 |
the situation is analog for ac neutral but I would not bet on it the one time i measured the voltage between neutral and earth it was a few volts but supposed to be 0 also you have to be 10000000000000 % sure of the system you are dealing with
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| | #11 | |
| | #12 |
The only problem with relying on the neutral for protection is if there's a break in it the case will become directly connected to live!
| | #13 | |
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | ||
| | #14 |
haha, thats wierd "plug your washing machines in backwards and the case becomes live" hmmmm, thats nice and safe i wonder if it will spin backwards too?
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserchat.org IRC chat for laser and electronic related stuff. | |
| | #15 |
no it won't spin backwards else half washing machines in italy would, thats the reason for the seperate earth wire in theory we could use the neutral and connect it to the chasis but for safety reasons it's not a good idea, an italian plug is three pins in a straight line so unlike eglish plugs theres a 50/50 chance you plug it in one way or another but the motors always turn the same way
| electrical, safety |
| Science Fair Project - Electrical Storm Globe | electronicjuggalo | General Electronics Chat | 5 | 8th October 2006 03:33 PM |
| Confused about simple electrical safety concept (pics) | chson | General Electronics Chat | 30 | 29th March 2005 11:00 AM |
| Electrical forum | LordError | General Electronics Chat | 3 | 11th February 2005 11:03 AM |
| UK - 3 PHASE ELECTRICAL SUPPLY | Asjad | General Electronics Chat | 3 | 7th November 2004 08:49 PM |
| Safety interlock module | wilfredmike | Electronic Projects Design/Ideas/Reviews | 6 | 2nd November 2003 09:41 PM |
