OK, I am thinking about designing a multi-use box to drive both ignition coil drivers and flyback transformers (not at the same time, obviously).
The idea is to have a Visual Basic program communicate via serial to a PIC to tell it what waveform to generate, and have the PIC actualy generate the waveform to be applied to the primary of the device.
So basically PC->MAX232->PIC->Isolator (for spike protection)->Output stage
1)What waveform/duty cycle/etc is appropriate to drive a flyback? What voltage range do they take on the input? I have several surplus units but no specs. I've found ignition coils to work fine anywhere from 12-15V with a low duty cycle square wave, but the exact parameters depend very much on the individual coil and what frequency you're running at (basically each coil had an individual charge time, at which point you wanted to fire, and then just keep it switched off for the remainder of your period).
2) Is a simple low-side switch OK, or would I do better with a half-bridge FET system?
3) Any suggestions on this? I've found that arc discharges from ignition coils can reset the PIC, but twisting the wires that fed the coil and the leads to the arc gap fixed everything (basically they were acting as antennas). I plan on putting the entire system in an aluminum enclosure this time with power devices heatsinked through the case to some big ol' sinks I can find around work.
I figure this might be a useful project for others too, since people like to use these as HV sources and this would be a pretty slick way of controlling the device.
Good to about 20 amps at 365 volts.....
