Old 21st June 2007, 09:25 PM   (permalink)
Default Best way to power A white LED
What is the best way to power a LED under the following conditions?
a) Where Battery Life is of Most concern and LEDs are at moderate brightness
b) Where battery life is not of concern (or infinite) and you want the maximum brightness from a LED.
c) Where Battery life is of concern but you want the Max Britghtness from the LED's while conversing battery life.
Or, Which is better for powering White LEDs under condition C.
1) PWM
2) Just Using Resistors
3) Boost Converter
4) Constant Current Source
I want to re do my flashlight, but I want it to be efficient yet get the most brightness. This time instead of a 9V, I am going to use 6 AAA Batteries in series (Some where Ive read AAA's have a capacity of 2200mAh) to get 9V. Or just use two 9v in parallel to get more current.
Overclocked is offline
Old 21st June 2007, 10:04 PM   (permalink)
Try this...
http://www.joulethief.com/kit.php
Gives schematic and full details. Haven't built one, but thinking of doing something with it...
HarveyH42 is offline
Old 21st June 2007, 10:16 PM   (permalink)
The switching regulator in the link below features current limiting. You could easilly omit the zener and just use it as a constant current source set at 350mA for a lux star LED.
http://www.romanblack.com/smps/a04.htm
That's how I would do it anyway, you're better off with six AAA batteries than two 9Vs in parallel.
Assuming 80% efficiency (worst case) the current from the battery will be 213mA, enough to keep the LED powered for over 10 hours.
In practice if the circuit is well designed the efficiency can exceed 90% so the batteries should last even longer.
Screen name: Aloone_Jonez
Hero999 is offline
Old 22nd June 2007, 01:06 AM   (permalink)
In approximately the same volume, you're probably a lot better off with four AA batteries instead of six AAAs.
You may find still better energy density in a single D cell and the joule thief. (If my reading of the Duracell data sheets are correct, about three times as much).
I haven't seen a 2200mAH AAA, myself. Lots of AAs, though.
mneary is offline
Old 22nd June 2007, 01:13 AM   (permalink)
--------adjust joule thief (boost converter) to moderate brightness.
--------adjust joule thief for maximum rated LED current.
--------adjust joule thief for a little less than maximum rated LED current.
If you use a battery of 4V or more, substitute buck converter for boost converter. If you have several LEDs in series, the boost converter is almost always used.
mneary is offline
Old 22nd June 2007, 02:13 AM   (permalink)
I was going to connect the LEDs in series, and I may use a specialized Controller or just design a SMPS Boost converter from Scratch. Personally, Id rather sit down and design something, But thanks for the Idea's.
Ive got about 100 LEDs, But I think I might use something like 20 to 25 LEDs. I have seen the S-Flux (or piranaha) LEDs for cheap, they have a wider angle, but are physically bigger. Would S-Flux LED's be better suited for a flashlight?
(S-flux LED's are these things:http://www.lsdiodes.com/shop/index.p...=index&cPath=4)
Old 22nd June 2007, 02:42 AM   (permalink)
The voltage from alkaline batteries drops like a rock and so does the brightness of a simple flashlight.
The voltage from a rechargable Ni-MH battery begins lower than alkaline but the voltage stays much higher longer. Then you can charge it and use it again many times almost for free.
audioguru is online now
Old 22nd June 2007, 03:24 AM   (permalink)
Agreed. I should have mentioned that.... you need a regulator to drive an LED from alkaline. Since the LED relies on current rather than voltage as the prime driver for ratings and for brightness, it is ideally a current regulator.
NiMH has a flatter voltage curve, which is also a solution, with careful design (resistance choice).
mneary is offline
Old 22nd June 2007, 04:28 PM   (permalink)
I was assuming he was talking about using NiMH batteries and yes I don't think 2200mAh NiMH cells exist, I think he was confusing them with AA cells.
It makes no difference whether they're in series or parallel.
The advantage with parallel is you'll probably be able to build a higher efficiency converter and it'll probably be easyier to do too. The disadvantage is that you'll need a resistor for each LED which is no problem as resistors are hardly expensive.
For example if you use the simple constant current regulator from my previous post to power 10 white S-flux LEDs at 27mA each you put a 22hm: resistor in series with each LED and just use one of them as the current sensing resistor.
Conneting them in series can also be done but you'll either need a buck boost converter (the output voltage will be negitive rather than positive) or a fly back converter and just make sure that the battery voltage will never exceed the voltage drop of the LEDs (they'll overcurrent) and that the output of your converter can never become open circuit as (the components on the output o fhte converter will be subjected to a high voltage).
Hero999 is offline
Old 23rd June 2007, 05:19 PM   (permalink)
Thanks, If I understand correctly, either a Constant current source or a Boost converter is used to power LEDs.
Im still trying to decide if I should use 5mm LEDs, S-Flux LED's or Luxeon Star LEDs. 5mm's are small (when compared to the other 2) and still give a pretty good brightness. S-Flux LED's are a bit larger but have a wider angle. Luxeon Star LEDs are extremely bright, and have the same angle as a 5mm LED but requires the power of about 10 LED's (assuming Each LED gets 20mA each).
But the wider the angle, the bigger area you can see. If 5mm and S-Flux LEDs are compared against each other, they still have the same brightness and require the same current, but S-Flux (as mentioned before) have a wider angle. For this application, it seems S-Flux LED's are ideal. If I wanted a large amount of light in a concentrated Space (or if I wanted to light my room..), I would go for Luxeon Star LED's.
So S-Flux it is then!
Old 23rd June 2007, 06:54 PM   (permalink)
Here's a simple constant current LED boost converter. I modified it from a simple boost switching regulator. Efficiency is typically around 60% to 80% but you can probably make it even better if you know what you're doing.
R1 = 10k but it needs to be less than that for higher power levels.
R2 = Current sense resistor.
C1 = 4.7nF
C2 = 100µF
D1 = 1N4001 but a schottky barrier is better.
Most small NPN transistors will work for Tr1 and Tr2, 2N2222A, BC549 etc. but check the power rating.
The problem is the voltage drop of the diodes needs to be more than Vin or else the current from the power supply will flow though D1 and destroy the LEDs.
Hero999 is offline
Old 23rd June 2007, 08:39 PM   (permalink)
i have seen aaa nimh in 1100mAH capacities. mostly either varta or camlean
Regards,
Sarma.
mvs sarma is offline
Old 23rd June 2007, 11:04 PM   (permalink)
C1 = 4.7nF
C2 = 100µF
But how much voltage do you actually need on the output? If I run them all in series, Im assuming # of LED's * Vled would give how much I need. If each LED drops a voltage of 3.5V and I have 15 LEDs (since I dont know how much space s-flux uses, I'll assume 15 can fit on a round PCB board) that would be 52.5V! Of course, If I connected 3 in series and then connected 4 banks of 3 in parallel I would only need 10.5V.
So, I'll go with a previous suggestion for using D sized batteries (These are just design considerations- I might not use Alkaline Batteries, but rather NiMh. But for Assumptions sake, I'll ne referencing to Alkaline's) and looking at the data sheet for Energizer Batteries, They have a capacity of 20500mAh!! (which is 20.5Ah- Correct?) If a boost converter consumed even 1A, it would last 20hrs, @.5A 40hrs,@.25A 80hrs.
If I used that assumption (assuming each LED requried 30mA each), I would need 90mA per branch, which if there are 5 branches total, I would need 450mA total, in which .5A would be sufficient. So it would last 40hrs on 2 D batteries.
Old 23rd June 2007, 11:43 PM   (permalink)
The output voltage is simply the forward voltage multiplied by the number of LEDs. This circuit is most efficient when the output voltage isn't much higher than the input voltage but you want to ensure that the output is never below the input so you do need a reasonable margin for error. Yes, four banks of three is probably ideal, and six cells will give 7.2V which would be perfect.
The current supplied by the battery isn't the same as the current used by the LEDs if you're powering them from a switching regulator. If you're using a step-up converter then the battery will always supply a larger current than the LEDs are using and if you're using a step-down converter the batteries will always supply a smaller current than the LEDs are using.
For example:
V_{IN} = 12V
V_F = 7V'Total forward voltage for all of the LEDs in series.
I_F = 0.3A'Total forward current for all of the LEDs in parallel.
P_{OUT} = 7 \times 0.3=2.1W
P_{IN} = \frac{2.1}{0.8}= 2.625W'Assuming 80% efficiency.
I_{IN} = \frac{2.625}{12}=0.21875A
If you're going to use a NiMH D cell then make sure it's a real D cell, lots of NiMH D cells are AA cells in disguise.
Hero999 is offline
Old 24th June 2007, 12:52 AM   (permalink)
For example:
V_{IN} = 12V
Dont you mean 10.5V? Assuming 3.5V for each LED, and 3 LEDs in each bank, thats 10.5V @30mA per bank.
Draining capacitors on power supply hfireworks Electronic Projects Design/Ideas/Reviews 24 27th April 2007 03:03 AM
white led driver akshayd Electronic Projects Design/Ideas/Reviews 6 28th January 2007 02:02 PM
Ultra low power power supply steevke Electronic Projects Design/Ideas/Reviews 1 3rd February 2006 04:46 AM
Power Supply for a project to be powered within an Auto? hexibot43 General Electronics Chat 16 8th September 2005 03:36 PM
Power supply: Fusing to protect circuit Johnson777717 Electronic Projects Design/Ideas/Reviews 4 10th April 2004 03:19 AM
