Old 16th June 2007, 08:17 PM   (permalink)
Experienced Member
madmikejt12 is on a distinguished road
Default Current limiting
Hi, I would like to lower a current from 15-17A to around 200mA is this possible, cheap and easy to do?
thanks,
Mike
madmikejt12 is offline   Reply With Quote
Old 16th June 2007, 08:32 PM   (permalink)
Super Moderator
You need to tell us exactly what you're trying to do, your post makes no sense!.
Old 16th June 2007, 08:37 PM   (permalink)
Experienced Member
sorry, its for a in-car CD player (ive hooked it up to my speakers and a computers' PSU). I want flashing LED's that flash to the beat, i've measured the voltage at about 3V and the current 13-17A
Old 16th June 2007, 08:46 PM   (permalink)
Super Moderator
For a start you don't measure the current like that - you will probably kill the PSU (and perhaps your meter?). As long as the voltage is correct (or reasonably near) the unit will only take the current it wants - as long as the supply can provide that much, or higher, it will be fine.
But NEVER place an ammeter across the output of a PSU, it's not measuring anything useful at all!.
Where you should place the ammeter is in series with the +ve lead to the player, it will then measure the current it's drawing.
Think of the PSU as a barrel of whiskey!, you only drink it slowly, a small glass at a time - you don't have to drink it all down in one quick swallow!.
Old 16th June 2007, 08:51 PM   (permalink)
Experienced Member
it was the speaker outputs i put it across (+connection and -connection)
the current was from the speaker output from the cd player, not the power supply, it is different isnt it? If i connected an LED with current limiting resistor, the LED would blow wouldnt it?
Old 16th June 2007, 09:22 PM   (permalink)
Super Moderator
That's an even worse place to put it, and is even more useless - and is VERY liekly to blow the amplifier.
No it wouldn't, you've just said CURRENT LIMITING RESISTOR, that will limit the current to the value you design. But in this case as well, any current capability of the output is completely irrelevent - it's the VOLTAGE you need to know. But neither that, nor the current can be measured by a DMM.
Old 16th June 2007, 09:28 PM   (permalink)
Experienced Member
if its the voltage i need to know, but cant measure it..... does this mean that i can either risk it or not try it?
is it safe to put a large resistor and an LED directly to the amplified speaker output?
Old 16th June 2007, 09:34 PM   (permalink)
Super Moderator
Use ohms law - presumably you know the claimed output of the amplifier? (which will probably be far higher than it actually is), and the speaker imedance - it's simple to calculate the peak or RMS output voltages.
Yes - however, why do you want to do this? - it works really badly, you need to filter the audio and use a monostable to give a decent flashing LED effect.
Old 16th June 2007, 09:44 PM   (permalink)
Experienced Member
it says on this PDF i have:
Allowable input : 45 W or more
Impedance : 4 – 8 Ω
So...
V=P/I
V=45/8
V= 5.625 (maximum voltage??)
is this correct?
and the current will only be drawn as needed?
the monostable circuit.... do you mean having a short time delay with the trigger connected to the speaker output (where an op-amp or shmitt trigger would be requited presumably?) and what about a filter? what type of filter do i need?
if this is completely wrong, do you have a circuit/block diagram please?
(sorry I am only at GCSE standard with my electronics, just finished the course, ive only ever used low power devices and have not really used much audio electronics)
I would like to say thank you to everyone who has helped me, I enjoy learning new things and eventually, i would like to be really good at electronics
Mike
Old 17th June 2007, 12:30 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
Most LEDs have a max allowed current of 30mA and a max allowed reverse voltage of only 5V. Therefore you need to limit its current and rectify the audio.
The rectified audio will light the LED very dimmly.
Make this very simple rectified monostable circuit:
Old 17th June 2007, 01:06 PM   (permalink)
Experienced Member
ok, thanks i will have a go at that soon
Mike
Old 17th June 2007, 01:32 PM   (permalink)
Experienced Member
it gives the same effect as what the bulb does on its own (but the bulb is brighter)
Mike
Old 17th June 2007, 01:49 PM   (permalink)
Experienced Member
I have decided to go with normal bulbs.... I would like to use 4 12v bulbs (1 per speaker output) and connect them how the current bulb is connected (it is a 12V bulb from one of those bright lamps that get really hot)
Would these work: http://www.maplin.co.uk/Module.aspx?...0bulb&doy=17m6
and most importantly, would it be safe? The power supply I am using to power the CD player is around 350w
Edit: at +12v, the PSU delivers 18A max
Mike
Old 17th June 2007, 02:22 PM   (permalink)
Experienced Member
The 12V light bulb is 20W when it is operating at about 2000 degrees C. But it is about 200W when it is cold and then it might damage the amplifier that is rated for only about 14W per channel.
Old 17th June 2007, 02:44 PM   (permalink)
Experienced Member
ooh, didnt know it was only 14w per channel.... didn't know what it was to be honest!!
how about 10w Halogen bulbs??
or these bulbs (5W) http://www.maplin.co.uk/module.aspx?...4&doy=17m6#faq
or a relay http://www.mutr.co.uk/catalog/produc...e86de32bfcd00e
http://www.maplin.co.uk/Module.aspx?...relay&doy=17m6
http://www.rapidonline.com/productin...moduleno=29524
what voltage/current relay do i need? 6V or 12V
Does the current need to be low? so it switches at say 2 or 6A? or higher than the max. output?
Really sorry to be a pain, hope you dont mind all the questions.
Mike
Mike
Need advice about this AC Line Current Detector Avocado Electronic Projects Design/Ideas/Reviews 6 21st March 2008 05:36 PM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 05:35 PM
PIC16F84A + 4017 Decade Counter + audio question Peter_wadley Micro Controllers 30 14th April 2007 03:38 PM
Current and Conductivity ElectroMaster Electronic Theory 1 2nd February 2007 12:49 PM
Current Limiting Mosfet nav2u Electronic Projects Design/Ideas/Reviews 1 7th March 2006 07:23 PM
