| i just got a neon sign transformer and it had this little box connected to the primary windings. I have an idea of what it could be (current limiting?) but was not sure. It says on it... neolite neon, OCM-B, Amps:1.5-2.5, Voltage: 240 AC and then all the aproval numbers and whatever. When i tap it, it feels like there is a spring of some sort in there (resistor?). does any one know what it is? Thanksthing 1.PNGthing 2.PNG
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
| hmmm, so i'm guessing no one knows what this is?. i have posted a similar question on another forum but they don't know what it is either?
| Oh, i didn't notice the capacitor section there. when i tap it, it feels like there is a spring in there or something? It's says its an OCM, does anyone know what that stands for?
| OCM = Open Circuit Monitor | |
| So what would the OCM do?
| It monitors the output voltage, when it rises above a predetermined level, ( as would happen with an open circuit ) it disconnects the output. This is a safety requirement in most areas, to prevent shock hazard and arcing/fire hazard if the neon tube was broken or a cap came free of the tube. It often contains a fusible link on a spring, that burns open and the spring ensures the contacts are separated. THis is likely the vibration you noticed. Last edited by zevon8; 17th June 2007 at 02:29 PM. | |
| You might need to disable it if you're going to use it to power a project.
