I have here a car CD player. However, I am not old enough to drive so havnt got a car! I was wondering if there was an adaptor available to plug it into the mains for power? there is phono out at the back so I would connect my speakers to there
It needs a 12V supply and the max current is 15A.... baisically, I want to use a in-car cd player, without the car |
yes, you can hook it up outside the car, but i don't know if there is any adapters with the right plug on it? Could you post some pictures of the back and power plug?
The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. |
ok, here is the back:
![]() the black plug and socket (plugs into each other): ![]() the red plug (plugs in the car): ![]() im guessing the red and black leads are the power? could i use something like this: http://www.outdoorgb.com/p/230v_12v_...BP&country=GBR ?? and plug my speakers into the phono sockets? Last edited by madmikejt12; 15th June 2007 at 10:21 PM. |
just to confirm, the cd player will only draw whatever current it needs from the player? (unless there is an electrical fault causing the fuse to blow)
also, the CD player has a 15 amp fuse which suggests it requires a high current, the adaptor only gives a 5A output, does this matter? |
well with my cd player, the speakers connect to one one of the plugs inside the big plug on the right. you just have to find the power input and speaker outputs. How many speakers were hooked up to it in the car? 4?
i dont know, sorry.... it was my sisters in her old car.... i dont have a car as i'm only 16... my sisters just given it to me for when i get a car (which will probably have a cd player in anyway!!) but i wanted to use it in my room
i think there where 2 in the front ant 2 in the back.... the phono outputs will work fine wont they? (the speakers are amplified) so its just a case of getting the power to it? is there a cheaper way of getting a 24V high current supply? or would you reccomend one of those power adaptors? Last edited by madmikejt12; 15th June 2007 at 10:50 PM. |
there are 2 leads with labels on.... a yellow one labelled BATTERY 15A and the other one is red labelled ACC
there is also a black one (which is next to the red one in the black plug, and in the red plug aswell) |
well one or two of the wires are so it turns on when you turn the keys, two goes to the power and if there is one wire with a plug on the end it could be for the power arial (spelt correctly?) if it had one. and then the rest goes to the speakers. i don't really know much more about this one? Hmmm
The phono jacks are labelled "pre-out" so they feed an external amplifier, not speakers.
The big connectors probably have the connections for four speakers. A 12V/5A power supply will probably operate it but the power output will be low before the power supply blows up or severe distortion results.
Uncle $crooge |
What you want to do should be pretty simple.
I would help if you had a wiring diagram for it. I would guess the red to be power and black to be ground, but I can't be sure. Most stereos I have worked with have a: Ground Power lead thats hot all the time for memory Power lead thats hot only with the key on Input to dim display when the headlights are on somtimes an output to control a power antenna or amp and then all your speaker wires - 4 speakers - 2wires each - 8 wires total |
so even amplified speakers would not work with the phono?
and if i get the powre correct, ive then got to figure out which 2 wires i need 2 touch to turn it on? and the power supply wont last very long? is there anything you can reccomend? (apart from a car battery) |
sorry, replied before the last post.... sorry i do not have a wiring diagram, the wires are in pairs...
green-green next to each other white-white purple-purple gray-gray then blue and white lead and aslo a lose blue lead with a rubber insulator at the end (antenna??) going to the same socket the red and black are close to each other and the yellow is on its own (this is in the black plug) I will try and draught a diagram for you are the speaker outputs amplified or not? here is where the coloured wires are: ![]() I'm guessing top is speakers, bottom is power? Last edited by madmikejt12; 15th June 2007 at 11:21 PM. |
Without a wiring diagram then you are just guessing. If one wire is wrong then the CD player will blow up in a cloud of smoke and never work properly again. Good luck.
Of course it has amplifiers for 4 ohm speakers. They are probably 14W per channel at clipping if the power supply is 13.8VDC. When all four channels are producing 14W each then the CD player heats with about 56W. So the unit draws a max current of about 8.2A for the amplifiers and some more current for the CD player's parts.
Uncle $crooge |
i dont like the sound of "cloud of smoke" 'electronics' smoke stinks!!! ive had a capacitor explode in an audio amplifyer (too much current i think)
if I was only using 2 channels (28W) what would the max current be then? the power adaptor listed above has a max output of 5A and 60W |
found some info
would this speaker work? http://www.maplin.co.uk/module.aspx?...=16m6#overview I only want low wattage speakers, 2 of these gives 12V so, with 2x 6W 8 ohm speakers (lets call that 18W to account for the player and any extra) the current drawn from the player is 1.5 amps, correct? or have I done something wrong? Last edited by madmikejt12; 16th June 2007 at 12:28 AM. |
| car cd player won't work | Hank Fletcher | Chit-Chat | 14 | 2nd September 2007 08:12 PM |
| Turn Cd player to MP3 | sharkfish | General Electronics Chat | 13 | 16th May 2007 02:54 PM |
| Problems with MP3 player | ianmc38 | General Electronics Chat | 4 | 31st May 2005 11:24 AM |
| car tape player and cd player | Burnz316 | General Electronics Chat | 2 | 15th January 2004 07:52 AM |
| Digital Optical output for MiniDisc Player | Peter | Electronic Projects Design/Ideas/Reviews | 1 | 20th January 2003 04:19 AM |
