| Its my first time making a pcb, well actually when I typed This it was etching, So I was Wondering: What to get: What to Use: Suppliers of stuff: Hints: any other thing: Also, where can I find really small drill bits, along with hints on IC holes | |
| Nigel: Oh! thats where I went wrong (ha ha)! Hero: I am a super noob, so sodium persulphate and magazine paper could mean anything to me. I AM JUST STARTING THIS TODAY LOL! | |
| Also, it says to dump the ferric chloride down the toilet! Is this right?!? | |
| First, search this forum for threads about making PCBs, toner transfer, drill bits... We go through this about once a month, so plenty of good reading, some even a little amusing. Search the web, there are at least 2 good sites with are almost totally dedicated to making PCBs at home, many good links to suppliers. More than you probably need to know. Electronic Goldmine has carbide PCB bits, had some on sale a month ago 50-$29, if you have a drill press, likely a lifetime supply. In a dremel or regular drill, probably a year or two worth... Think the also had a small assorted size deal around $5, likely best to start with. Anyway, no matter what method or tools you use, the number on all time, most important thing to remember... Clean the copper well, and keep your greasy fingers off it until it's done etching. | |
| I finished etching, and I made a simple LED flasher using a 555. It looks and works good. I think i am going to try PCB more often! | |
| Advanced Circuits always does a whiz-bang job for me | |
| i used perminent marker, but how do i use the magazine paper way? Do i use the same echant and eching process? if so, Plz tell me! | |
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | ||
| Remember that you cannot fit a square pin into a circular hole if the hole has a diameter equal to one side of the pin. And don't bother etching away all the copper on the PCB that's not needed unless it's in under or around an area that is sensitive to extra capacitance like clocks, etc. Wastes chemicals and causes waste. Just ground it- provides more stability and prevents your board from warping (the ratio of copper-plastic is more equal throughout the board). | |
| dknguyen, I know you are right, there was a test on that when I was maybe 4 years old. Damn thing did not fit, but a bigger kid got his square peg in the round hole and his face was all red... On a side note. If you use Eagle, go to the pad layer and use the poly tool and cover your open areas and leave the chucks of copper on the board and save etchant. | |
| Name your ground GND then type in "polygon GND". It will prompt you to draw the polygon. Draw around the edges of the board and all the areas it fills will be connected to GND. Use change ISOLATE to set the distance between the fill and other signals. It will not fill till you use RATSNEST. Once you do POLYGON GND you can not change the value of ISOLATE. You have to undo the POLYGON cmd and then change ISOLATE. HTH
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
__________________ Superman returns.. | ||
| ULTRA clean 9VDC Power Supply Project | Peter_wadley | Electronic Projects | 47 | 19th November 2008 01:54 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Programming sliders in JustBASIC? (Mike I know you know this stuff :) | blueroomelectronics | Micro Controllers | 11 | 9th April 2007 02:33 PM |
| User defined Time period 16f628 | jagrolet | Micro Controllers | 4 | 5th September 2006 08:37 PM |
| Time base interrupt | atferrari | Micro Controllers | 5 | 8th May 2005 01:31 AM |
