Hi all!
I’m using LM 317T constant current circuit (as in the data sheet) to charge my NEW 6V SLA battery. The NEW battery I checked the voltage. It shows 6.2V. 1)When I use constant current circuit it shows 0 current when charging. Why is this? The R1 I calculated 2.7 ohms. 1.25 / 450 = 2.7 ohms. I used a 6V transformer to give the supply. The DC voltage showed 8.1V in the regulator. Battery specifications Capacity 6V / 4.5AH Cycle use 7.25 – 7.45V 2)When I use constant current circuit will it charge all the time with the calculated current (450 mA) or will it decrease when the battery voltage increases? Thanks |
First off there is 1.25 volts drop across the constant current resistor and about 2 volts drop across the regulator itself so you don't have enough voltage a the battery terminals to charge the battery. It is best to have a little extra input voltage to the regulator.
The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. |
The battery needs 7.45V.
The 2.7 ohm resistor needs 1.25V. The LM317 nees 2V. So you need a DC source of 10.7V minimum when it has a 450mA load.. You have only 8.1V without a load.
Uncle $crooge |
Ok thanks. Then I will use a 12V transformer.
Will the battery overcharge if I use constant current with this 12V transformer? Note: I need constant current, not constant voltage / current limited type. |
lead acid are flexible in their charging requirements - you should visit google and read about it, there is a lot of information
the easiest way is the constant voltage charge - which is printed right on the battery (7.25 to 7.45). build your lm317 to output 7.4 volts and thats all you need to do. when the battery is low, it will draw a large current as the regulator tries to pull the battery up to 7.4v. as the battery nears charge, the current will decrease. by 'cycle use,' they mean you cannot float-charge the battery at this voltage, as it will damage it eventually. consult your vendor or datasheet for a float charge voltage. it may be listed as 'standby use' or standby voltage
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
Thanks justDIY.
Then I will make a constant voltage type with LM317T.Need only two resistors. Then the battery will draw its own needed current. My battery says STAND BY VOLTAGE 6.8V – 6.9V what is this? Do I have to adjust the charger to 6.8V? What’s the transformer do I have to use? Thanks. |
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Hi Eric I’m going to charge my batteries once in a while (once a week or two).
I will use cyclic voltage 7.4V. I will make the constant voltage circuit (the two resistor circuit). Is it ok? Not the constant voltage/current limited one. The constant current circuit I made but it’s charging current showed 0. I think the transformer in not enough voltage as earlier mentioned by others. Now I’m going to use 12V / 500mA one. |
I like these designs for a very simple current limited constant-voltage charger:
http://www.vt52.com/diy/myprojects/o...er/charger.htm The current limit is really only needed if your power supply is very strong - the small transformer you mention 12v/500ma will already be limited in its current capacity. Another thing to consider is input smoothing. If you indeed have a transformer and not a power supply, the input voltage will have ripple in it. large capacitance on the input to the regular will be required to keep it from dropping out as the AC voltage does its sine-wave thing. An argument could be made however, that this dropout is not a bad thing. The drop-outs will cause pulses in the output of the charger, which research shows is good for a lead acid battery.
Are you sure you want constant current?
Most lead acid batteries are better charged of constant voltage. I would float charge it to 7.0V, the internal current limiting in the LM317 should be sufficient to stop anything nasty happening.
don't use 7.0 volts. use the voltages supplied by the manuf, printed right on the battery.
use 6.8 to 6.9 for continuous worry-free charging or use 7.25 to 7.45 for fast charging, which you will need to monitor to avoid damaging the battery.
| Constant Current Source (CCS)? | him27hk | General Electronics Chat | 1 | 26th November 2006 02:25 PM |
| Resistors | Marks256 | General Electronics Chat | 52 | 3rd August 2006 01:00 AM |
| how to build a voltage controlled switch | terramir | General Electronics Chat | 9 | 24th May 2004 06:23 AM |
| How to make constant current source | j2bichon | Electronic Projects Design/Ideas/Reviews | 12 | 11th August 2003 02:47 PM |
| Charging problem | thebigbasicq | Electronic Projects Design/Ideas/Reviews | 4 | 6th May 2003 11:20 AM |
