| Notices |
| | (permalink (permalink)) |
| i am looking for a circuit which has the follwing oparation: when i give voltage to this circuit (12 v dc), after a time (approximately 40sec-1min) this circuit to give 12 volts dc to a relay (12v dc/ 230 volts). i want this time to be variable with a variable resistor. the circuit i am looking for is a power-on delay circuit. i have listen many ideas like cd4060, CD4541 lm555 but i have not a circuit. please help me and post a circuit here. thanks | |
| Come on it's not that hard really. I'm in a good mood so I've done it for you but I won't give you the component values, you can calculate them for yourself.
| Here is the simplest circuit with 3 parts only. R2 is your relay that closes with delay and R1*C1 determines the delay, so if we simplify and disregard the input current to base, the delay would be proportional to R1. I used two power sources for simulation but they can be merged into one. Picture #1 is the schematic, picture #2 is the voltage over time graphs and ZIP contains LT spice schematic so you can play with it. This circuit is just a hint. Massage it in the SPICE software and determine your values.
__________________ www.dipmicro.com Last edited by dipmicro; 4th June 2007 at 12:24 PM. | |
| http://relays.tycoelectronics.com/datasheets/CD_DS.pdf I would use the 12 volt 2 to 180 second delay relay. rons | |
| thank you all of you for your answers except hero999. on1aag i would like to ask you about the time delay that your circuit has. i would like to be between 40-60 sec approximately.i would like the relay to be on power-on state after these seconds. before these second i would like to be on power-off state. | |
| What's wrong with my answer? It works!
It can be fixed though. ![]()
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | ||
This is not what you said in your OP, why??? Many members have wasted time and effort trying to answer your original query!
| delay circuit? | aerial | Electronic Projects Design/Ideas/Reviews | 3 | 11th August 2006 05:29 PM |
| Circuit for edge delay, signal on timeout | tim__ | Electronic Projects Design/Ideas/Reviews | 1 | 4th October 2004 02:06 AM |
| Power supply: Fusing to protect circuit | Johnson777717 | Electronic Projects Design/Ideas/Reviews | 4 | 10th April 2004 02:19 AM |
| How to build a simple time delay circuit? | happytanker | Electronic Projects Design/Ideas/Reviews | 5 | 7th April 2004 03:21 AM |
| light depended circut together with its power supply circuit | thabit ahmada | Electronic Projects Design/Ideas/Reviews | 1 | 28th March 2004 06:23 PM |
