Experienced Member
Hi everyone,
Please see the attached file for reference to a question I've recently been given as part of a test. The question involves a capacitor charging from a supply at the changeover of a switch and I would normally find this kind of question very easy - you just use the formula VC = VS . 1- e-t/rc and transpose if you need any of the other variables (taking natural logs of both sides if necessary) However, this particular question has confused me because you've got a capacitor charding via a fixed potential divider circuit. With the values given, this means that the capacitor can only charge to a maximum of 9V, because when fully charged the capacitor will be an open circuit and at that time the output of the potential divider will be 9V... right? The first part of the question asks what the initial current will be. Well, if we're assuming that the capacitor starts off completely discharged, then initially it will be a short circuit so the current would be the supply voltage (18V) divided by the resistance of R1. Negligable current would flow through R2 due to the short circuit of the capacitor. And this is where I start becoming confused. As the capacitor charges up, it will become more and more resistive. But then it's in parallel with R2, and I was unsure how this would effect the formula I originally quoted. The rest of the question goes on to ask how long it'd take to charge to a particular voltage, what voltage would be across the cap after a certain period of time etc but I'm guessing you can't use that formula anymore? If you can, what do you put for R in the equation?!?!?! If only he had left out R2, I'd have flown that question. Brian
--------------------------------- Electronics Test Development Engineer --------------------------------- |
Experienced Member
It is a question of transient analysis...
I do not recollect the formulae right now... But once you switch on the cap, There is a short transient respose and later there is a sustained steady state. So do not look at the circuit from DC point of view. Added later... You can consider the cap short to being with. charging with the time constant R1 C later a resonance condition is to be considered of R2||C and teh steadt state is when C is charged to a potential equal to Es x R2/(R1+R2) ... I think...
Bharath Bhushan Lohray. M.Sc. Electronics. Last edited by lord loh.; 30th May 2007 at 12:39 PM. |
Experienced Member
Thanks for the response. I would agree with your comments, and infact I'm not confused on those matters. I understand that the initial condition would be for the capacitor to be short circuit, and I understand that the steady-state condition would be for the capacitor to be an open circuit with it charged to the output of the potential divider (or close to it)
My confusion surrounds what happens in between these two extremes. It's no longer as simple as using VC = VS . 1- e-t/rc because the charging resistor is no longer a constant, it changes as the resistance of the capacitor changes because the cap is in parallel with R2. Brian
Experienced Member
The in-between condition is the transient state... I do not recollect the formulae.
But the graph of current versus time shall take the form of a damped oscillation. and finally be a DC line. The in between state is that of the damped oscillation or the transient state. and the DC state is the steady state. Sorry for not being able to help you further. I am not good at remembering complicated (even the simple ones) differential equations such as the one which represent the inbetween transient state.
Bharath Bhushan Lohray. M.Sc. Electronics. |
Experienced Member
Also, the similator might be a great help. |
Experienced Member
Brian
Experienced Member
hi brian,
Consider the resistance R1 as the source impedance of the voltage source. Use Thevenin's theorem to solve the problem, the voltage rise across the Cap will be exponential. [which I suspect you already know].
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Experienced Member
See the attachment.
Experienced Member
Eric, Eng1.
Hmmm, I think you're right. R1 could be considered the internal resistance of the battery, although it's a very high value. In any case, I guess you could determine the equivalent circuit and answer the question that way. Thevenin's theorem it is, then. Pity I couldn't have thought of that during the test!!! Thanks all, Brian
Experienced Member
hi brian,
A final thought, why dont you construct the circuit, you have the values, use a CRO??... It will prove the result. Eric
Experienced Member
And I think you need a real good CRO to to transient analysis - a storage one.
Experienced Member
Experienced Member
Sorry Ron H, I do not follow. How do RC Oscillators like the wein's bridge, Phase Shift and Colpitt's work?
Experienced Member
Simply take the Laplace transform, solve the circuit with appropriate IC and take the inverse. Its the blind mathematical way to do it.
Experienced Member
LaPlace Transform?? Please don't sware at me!!!
hehe thanks for the suggestion. Brian
| Open Book Test Question | raywl | General Electronics Chat | 3 | 5th November 2006 06:41 PM |
| Basic Transmission question | CamNuge | General Electronics Chat | 2 | 8th March 2006 10:08 PM |
| High speed data logging question | cubdh23 | Micro Controllers | 3 | 19th August 2004 11:54 AM |
| Data Logging question with high speed!!!! | cubdh23 | General Electronics Chat | 4 | 16th August 2004 06:33 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 06:21 PM |
