Old 1st June 2007, 02:24 AM   (permalink)
Originally Posted by lord loh.
Sorry Ron H, I do not follow. How do RC Oscillators like the wein's bridge, Phase Shift and Colpitt's work?
Sorry, I should have said that in a passive circuit (no amplifiers), there can be no resonance in the absence of inductance.
Ron
Roff is offline   Reply With Quote
Old 1st June 2007, 03:34 AM   (permalink)
For the time constant, R1 is in parallel with R2 so TC = .5mS
FRIED is offline   Reply With Quote
Old 1st June 2007, 04:14 AM   (permalink)
My guess is that Vth is 9v, Rth of 500 ohm, so tau will be 500 micro seconds, thus full charge of 9v at 2.5 milliseconds.
It would be good to build and measure....
BeeBop is offline   Reply With Quote
Old 1st June 2007, 10:46 AM   (permalink)
I guess the inductor, in practical cases has some losses and needs soem energy to be fed into the tank circuit to compensate these losses. So I believe that there is no way to create an osicllator without an amplifier. Tell me if I am wrong.
Do you mean sustained oscillation when you say resonance? or do you count transient responses as well?
Now that 3iMaJ, mentioned the Laplace Transform, I am recollecting a few things.
Bharath Bhushan Lohray.
M.Sc. Electronics.
lord loh. is offline   Reply With Quote
Old 1st June 2007, 11:10 AM   (permalink)
R1 is not in parallel with R2, it is in series with R2. However, once the capacitor becomes resistive, it is then in parallel with R2 which means the "R" variable in the equation is no longer a constant.
Brian
Electronics Test Development Engineer
ThermalRunaway is offline   Reply With Quote
Old 1st June 2007, 12:10 PM   (permalink)
hi brian,
Couldn't stand the suspense!... Built the dam'n cct.
Time constant without R2, Tc= 1.1mSec
With R2, Tc= 0.5mSec, which ties in with 'eng1' graph.
Both curves are exponential which they should be!
Regards
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 1st June 2007, 12:42 PM   (permalink)
No, R1 is not in parallel with R2 and it's not in series with R2. But the RC constant can be calculated with an equivalent resistance Req, that equals R1//R2. This is a consequence of Thevenin's theorem. See the attachment and use your formula with the second circuit. Veq=Es*R2/(R1+R2)=18/2=9 V. Req=500 ohms.
eng1 is offline   Reply With Quote
Old 1st June 2007, 12:58 PM   (permalink)
In an ideal circuit (like a test problem) capacitors and inductors have NO losses - they are ideal.
Remember for oscillatory behavior, there needs to be both inductance and capacitance.. if the circuit contains only 1 type of energy storage element, then it is First order and oscillation CANNOT occur.
I would not go as far to say resonance since that requires a particular condition setup in the circuit (C & L values & FREQ of operation)
Things that oscillate are not necessarily resonant.
Optikon is offline   Reply With Quote
Old 1st June 2007, 01:20 PM   (permalink)
You are correct.
See the Wikipedia topic "RLC Circuit".
Ron
Old 12th August 2008, 03:44 PM   (permalink)
Laplace transforms? Oscillation? Guys, this is a DC circuit. No need for AC analysis, and there should be no oscillation, simply decay.
piper91765 is offline   Reply With Quote
Old 12th August 2008, 04:48 PM   (permalink)
hi piper,
I dont think you are working in the 'time domain'..
The post is a year old.!
Eric
PIC tutorials:
Open Book Test Question raywl General Electronics Chat 3 5th November 2006 06:41 PM
Basic Transmission question CamNuge General Electronics Chat 2 8th March 2006 10:08 PM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 11:54 AM
Data Logging question with high speed!!!! cubdh23 General Electronics Chat 4 16th August 2004 06:33 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 06:21 PM
